03-31-2009, 04:11 PM
used sparkplug in new(?) engine
Today I was going to begin installing the chain on my bike. The engine came with a sparkplug installed and a spare one in a plastic bag. The supplied wrench would not fit the plug or the gear so I got my own wrench and removed the sparkplug. This sparkplug was black and smelled of fuel. I received the kit in early February and have made little progress. The other plug in the bag is nice and shinny. I put my thumb over the plug hole and turned the drive gear and it has compression. The plugs are LD Z8C. I wish I had a camera to send a picture. This makes me wonder if I have a new engine. It looks new...How could I have a used spark plug in a new engine? Has anyone experienced this?
Thanks,
Pedal Pusher
03-31-2009, 04:37 PM
Re: used sparkplug in new(?) engine
Take the head off and have a look see.
03-31-2009, 04:53 PM
What Pablo said...and I'd also look for signs that the engine had been mounted before. Check the mounting areas and the bolts/nuts for evidence that a wrench had been applied. I recall reading here somewhere where a member had received an obviously used engine and his seller wouldn't do anything about it. Who did you buy the kit from and have you contacted them? Good luck, keep us posted, please.
03-31-2009, 10:09 PM
i have an engine like that, and i took the head off to check, everything inside is black and oily. im not too worried, i think the place i orderd the engine from does a quick test before they ship, it came with the cdi attached to the spark plug and magneto. It came with a black powdercoat and it does not look like it was already used.
04-01-2009, 04:28 AM
Don't some manufacturers test engines before shipping?
I want 2 ride my bicycle
04-01-2009, 06:13 AM
You've not seen the test video?
04-01-2009, 06:43 AM
Yes, but has been a good while since I bought a china kit. That vid does not really mean they do or don't pretest.  Really don't recall.
Peddle pusher, 2 of the kits I have purchased, arived with obvious signs they had been started b4. Both are still running. I bet that was worrisome. I will find out and let you know
04-01-2009, 07:01 AM
After spending lots of time thinking about it, the engine has to be new as both my friend and I examanined and inventoried the kit when I received it. Everything appeared new and there are no signs of scratches any indications any part had been used. The black electronics cdi unit was attached to the plug wire and the wire to the plug. Anyway, I talked to the same guy each time at Gasbike and he said the warranty is good for six months. At my progress rate the warranty may expire before I get going. Maybe I picked the wrong bike (Huffy cruiser) but nothing seems to fit nor go right so far.....
Thanks for the input.
Pedal Pusher
04-01-2009, 07:10 AM
I have built 6 bikes in the last month every engine had oily plug from supplier. Must be normal.
04-01-2009, 08:09 AM
Dan - I was half kidding. The test video is just a silly thing to show how they are started with an electric motor and ran for what - 5 seconds? Hardly leaving stuff on plugs. Mine have been showroom new inside. Perhaps some vendors are now putting some run time on the engines. Not something I knew before, and not a bad thing.
| Thread Tools |
| Display Modes |
Linear Mode
