Old 03-31-2009, 01:26 PM
philymitch's Avatar
philymitch philymitch is offline
Default Let me pick your brain
Whats up guys I was just watching TV and had a thought. Some of us say a boost bottle helps throttle response and some say it don't work at all. Now what if you use the same set up but instead of the boost bottle you would use a propane bottle. So after the motor is started on gas you could interduce a small flow of propane gas to the mix using a torch valve. What do you guys think... could it be to much for the motors?
Old 03-31-2009, 06:49 PM
toytime toytime is offline
Default Re: Let me pick your brain
I don't think I'd play around with a bomb near my crotch!
Name:	bike on fire.jpg
Old 03-31-2009, 09:30 PM
mechanickid's Avatar
mechanickid mechanickid is offline
hahaha! wow toytime.
i dont know anything about this sort of stuff, but it sounds hard on the engine.
its only too fast if you cant stay on!
Old 03-31-2009, 10:38 PM
cityevader's Avatar
cityevader cityevader is offline
If using propane instead of 2-stroke gas, where is the oil going to come from?
Old 03-31-2009, 11:53 PM
philymitch's Avatar
You would still use gas and oil. The propane would be connected to the intake ...between the carb and the motor..... only when riding would you interduce the propane to the intake adding propane to the gas and oil mix. It might help with pulling some of those hills the motor might need some help with. i wouldn't run it to long with the propane...... Kinda like a shot of nos with out the hi price set up.
Propane is like 110 octane or 115 octane. Might give a little boost?
Old 03-31-2009, 11:55 PM
cityevader's Avatar
in that case, you're adding extra fuel...where's the extra oxygen going to come from?
Old 04-01-2009, 12:01 AM
philymitch's Avatar
I went and did some research on google and this is what I found it has the same concept as I have in mind just introducing the propane after the carb.
Propane-Fueled Moped
Old 04-01-2009, 12:09 AM
it seems like the problem with the system you linked was still getting more oxygen into the mix unless i read it wrong.
Old 04-01-2009, 12:18 AM
philymitch's Avatar
Yes he was trying to use the propane before the carb..... I think you need to use it after the carb in the intake as a boost.
Old 04-01-2009, 12:35 AM
philymitch's Avatar
Just found this as well just keep reading the have made a propane conversion for a 2 stroke.
Yugo-Tech Conversion Gas Systems Inc. - Complete Profile
site
Yugo-Tech
