12-24-2007, 05:30 AM
Administrator
removing handle bar grips
this used to be a bear of a task for me. you either had to cut them or rip them off. their is a quick and easy way to replace them. take your air compresor with a blowing tool and just lift a part of the end of the grip and give it a blast of air and they slide or pop right off. same as putting new ones on. give it some air and they slip right on. a small tip but a great one
12-28-2007, 09:20 PM
Manufacturer/Dealer
Not all of us have air compressors, but those that do will enjoy Cruiser's tip.
Here's a good one for those that don't...
To slide new grips on your bars...take a drop of dishsoap on your finger and smear it around the inside of the grip. The grip will slide up on the bar without a hassle, and the soap will dry up and help to stick it there.
Just so everyone knows...the stock grips from your bike, or a fancy pair of store bought grips can be used to replace the stock grips that come with the majority of bicycle engine kits (mine included). Just work the original off and use my above tip to slide the new grip on...it may be tight, but that is a good thing.
Yes, I really do ride what I sell...everyday.
www.chrishill.myknet.org
Home of the CH80 Bicycle Engine Kit...for those that want quality.
12-28-2007, 09:27 PM
Administrator
wow1 you mean you can slip them over the throttle grip. i have some really nice grips in my drawer of goodies and never tried but i sure am in the morning. thanks for the great tip chris
12-29-2007, 07:20 AM
Manufacturer/Dealer
They'll fit but they are tight. A drop of dishsoap smeared inside of the grip will help more than you can imagine.
I had to mention swapping the grips, because I know for a fact that a lot of bicycle engine kits come with very lame grips, lol...except for my engine kits
01-01-2008, 01:15 PM
Dealer
"Airless" removal
Hi if you don't have air, slide a dull butter knife, spoke or whatever under the grip, spray in windex, repeat till you can slide off that grip. I have done this many times. Old crappy grips I don't care about are slit with razor-knife.
Mike
01-10-2008, 07:14 AM
Re: removing handle bar grips
One more tip-
To remove the old ones, heat is our friend....boiling water poured (carefully) on them, or better yet, use a heat gun or hairdryer.
01-10-2008, 09:19 AM
Paul,
If you want to install new grips on your thottle, try motorcycle grips. One is bigger on the inside to fit the throttle.
Dan
01-10-2008, 09:35 AM
Administrator
cool thanks dan. i am going to head to the motorcycle shop and look at grips and some mirrors. planing on replacing my throttle i have a cheap plastic on and the better ones you can put your own grips on. will let you all know what i come up with
01-17-2008, 01:10 PM
LORD VADER Moderator
I use plain water sprayed in between the grip and bars while pryed open with a small flat bladed screw driver to remove the grips and like one of the guys said if your not going to reuse cut them off. Once I've sprayed in the water I twist the blade around the grip to let the water get all the way around and it will come right off.
I like the foam grips soft and they absorb the vibes cheap to get a couple sets for about $5.00 includes shipping on flea bay. to install spray a little water inside the grip and push it on They come with end plugs and I use a bar end mounted mirror on the left side that's really for the right side its on upside down but out of my way and easy to see behind me its also convex anyway it works for me. If you run into trouble with the grip on the throttle side I've used weatherstrip glue or quick set JB-weld to hold the grip in place being careful not to glue the grip to where it fowls up the throttle. There's some of my ideas and I'm sure there's plenty more so chime in and lets share the knowledge.
Norman
12-23-2010, 12:04 PM
To remove: Slide butter knife and add a dab of 3in1 oil in the 2, 6 and 10 spot.
Slides right off.
To add: BABY POWDER!!!!!!
I may be slow, but I'm not very accurate.
| Thread Tools |
| Display Modes |
Linear Mode
