Old 03-24-2009, 03:08 PM
philymitch's Avatar
philymitch philymitch is offline
Default Runs great at 20mph but
My bike runs good at 20mph and starts within 10 feet. All is good till you hit 23mph then the motor acts like it wants to die like starving for air or out of gas. I put a new spark plug and wire in, cleaned the carb. cleaned the air filter, and put all new gaskets on the intake, carb, and exhaust and the problem is still there it wont go away. If you have any ideas please let me know.
Old 03-24-2009, 03:12 PM
Bikeguy Joe's Avatar
Default Re: Runs great at 20mph but
Does it have a steady staccatto sound or does it cut out and then run O.K.?
The first one is too rich...move the needle clip up a notch. The second condition is from fuel starvation, and that can be caused by any number of things, including inadequate fuel flow, a float that is set too low or a gas cap that is not venting properly.
Old 03-24-2009, 04:05 PM
freewheeling frank freewheeling frank is offline
see my post:engine not 1oo percent. i stuck a oring between the carb and manifold and now the thing does not leak any air at all, i was having the same problew but i think this will fix it. read the post as there is more info there. frank
Old 03-24-2009, 04:24 PM
philymitch's Avatar
Thanks frank and Joe I have an o ring on the carb already. Mb monkey was helping me on the chat box and it was a fuel problem... my bike was to lean and the fuel filters were clogged.
runs a lot better know. Thanks for your help guys.
Old 03-24-2009, 06:48 PM
philymitch's Avatar
How do you set the float..... all my motor has is a u shaped brass piece held with a pin that has no adjustment. do you have to bend the u shaped brass thing.
Old 03-25-2009, 02:51 AM
DEATH4OF4's Avatar
DEATH4OF4 DEATH4OF4 is offline
I Had A Problem Like That, But Found My Carb Needed To Be Tweeked.then It Ran Fine. A Couple Of Times That Happened To Me Before That, But Stupid Me... I Had The Choke On...
Old 03-28-2009, 10:48 AM
theonlyhek's Avatar
theonlyhek theonlyhek is offline
I was wondering the same thing..., I cannot seem to find any pictures of the adjustment, before and after. I don't understand, and usually I do?!
Old 03-28-2009, 11:16 AM
philymitch's Avatar
I found a post by norman on the rebuilding a carb. On page 2 he shows how to adjust the float in the first pic. I guess its a guessing game on how mutch to bend the little clip but here is the post http://motorbicycling.com/f30/motori...ild-302-2.html
