Old 03-23-2009, 08:04 PM
Ravenshurst Ravenshurst is offline
Default ALMOST ready for a test ride, BUT...
a couple of questions first...my friends bike has 4 wires (3 + ground) on his kill switch, and I have a black ground wire & a red wire. When I was a young lad red meant hot, but I have black, blue, & white coming off of my mag. The black & blue connect to the coil....how do I wire up this *&^%^$ kill switch? Also, I think I hooked the throttle cable to my carb wrong. I have almost no movement in my cable. Maybe a 16th of a turn on the throttle. Does anyone have a pic, drawing or photo, of the correct way to connect the cable to the carb? I could try to explain in words the way I hooked it up, but I would probably just confuse the issue, & I don't have a digi cam. HELP!!
Ride Safe!
Gonzo
Old 03-23-2009, 08:18 PM
toytime toytime is offline
Default Re: ALMOST ready for a test ride, BUT...
Your kill switch , just hook the white wire to any one of the two wires from the switch and ground the other wire. The carb, are you sure it slid all the way down ? It only goes in one way. I'd start with that , let us know.
Old 03-23-2009, 08:58 PM
MB-Monkey's Avatar
here is a post with the info you need for the carb install.
http://motorbicycling.com/f4/carbure...build-195.html
Ride it like you stole it!
Old 03-25-2009, 12:11 PM
OK, the engine fired right up & sounded great...the rest of my problems, not so good, lol. The kill switch doesn't kill. I hooked the red wire to the white wire coming off the mag & the ground to the frame. The carb is stuck on WOT. When I twist the throttle, the entire cable housing moves, but I have no throttle control. I am being defeated by a few cents worth of plastic. GRRR! The bike looks pretty cool sitting in my driveway though, lol. I realize I am going to screw up all of this terminology, but here goes...when I remove the "cap" from the top of the carb, the throttle cable moves just fine, and the hollow "plunger" & needle valve slide up & down no prob. When I put it back together it's WOT time. Any help would be appreciated. Any Tucsonans make house calls? OK, just kidding. Seriously, I would appreciate any advice. Thanks.
Ride Safe!
Gonzo
PS: the screw/guide for the cable that goes into the "cap" (could someone supply me with the proper word?) is threaded all of the way down/in. I am going to try to thread it up/out right now.
Old 03-25-2009, 12:28 PM
"I am going to thread it up/out..." Well, that was useless, lol
Old 03-25-2009, 12:58 PM
Shadeslay's Avatar
Shadeslay Shadeslay is offline
When you take the cap of the carb out, look at the slide, it has two little bumps on it, one is lower then the other, if you look inside the carb you'll see two little grooves, match those up and your throttle should work fine. Basically just turn the slide around.
Sun Tzu: To secure ourselves against defeat lies in our own hands, but the opportunity of defeating the enemy is provided by the enemy himself.
Old 03-25-2009, 01:02 PM
TigerToothBikes.com's Avatar
TigerToothBikes.com TigerToothBikes.com is offline
UK Dealer
otherwise if the cable is too short and the sleeve long just snip a section out of the sleeve
For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at
www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
Old 03-25-2009, 01:37 PM
MB-Monkey's Avatar
sounds like the spring is not returning the slide to the bottom. yes the nip and grooves have to line up take the air cleaner off remove the carb from the bike and take the cap off the carb. be sure to drain it first. then check the line up one side of the slide is curved that should face the air cleaner.
Old 03-25-2009, 03:19 PM
AslansMonkey's Avatar
AslansMonkey AslansMonkey is offline
For the kill switch and assuming you have a 2-stroke...
Wire the black wire from the motor to the black wire on the CDI AND the black wire from the kill switch (forming a "Y" connection).
Wire the colored wire from the motor to the colored wire on the CDI AND the colored wire on the kill switch (Forming another "Y" connection).
The white wire from the motor is a 6 volt wire for powering something else, like a light, in conjunction with the black ground wire.
The kills switch, when pressed, forms a dead short across the CDI essentially robbing it of power, which kills the spark to the motor.
Old 03-25-2009, 03:42 PM
Shadeslay, my slide is just a little bit different, but that was almost exactly the problem! Thanks a lot. I just took it around the block, it worked perfect!!!
Ride Safe
Gonzo
