Old 03-23-2009, 08:48 AM
toker_ace's Avatar
Default New stretch cruiser build.
HELLO, I am going to order a new 80 cc premium from dax (Duane) and a new stretch cruiser from ebay.Can anyone tell me what extra I will need. Will the throtthe cable be long enough for the ape hanger bars, clutch cable long enough, and the chain? Any info would be greatly appreciated. thanks
Old 03-23-2009, 11:06 AM
RedB66's Avatar
RedB66 RedB66 is offline
Default Re: New stretch cruiser build.
Depending on where you mount the motor you will need two chains and possibly two tensioners. Chain slap is a factor with the stretch frames. Throttle cable should work fine with apes (forward mounted engine). Clutch cable is an easy fix.
MOTORBICYCLING.COM STICKERS
Old 03-23-2009, 08:33 PM
toker_ace's Avatar
so, if I get two chains and two chain guides I should be ready to go?I've built about five of these before, but never a stretch..duh
Old 03-24-2009, 12:23 AM
fenderhole's Avatar
fenderhole fenderhole is offline
this will absolutely fix the chain slap problem
eBay Motors: Motorized Bicycle Kit Parts Chain Tensioner Moped (item 310129537122 end time Mar-27-09 07:45:52 PDT)
also, i suggest the greenline stretch cruiser. they seem to be less problematic in the long run. you can check out the pictures of my bike, it may give you some ideas
http://motorbicycling.com/f15/greenl...iser-6659.html
Old 03-24-2009, 06:02 AM
toker_ace's Avatar
Thanks for the help!
