Old 03-22-2009, 08:37 PM
mazdaflyer's Avatar
mazdaflyer mazdaflyer is offline
Default New from Kansas
Used this forum to help assemble a RAW Motors Kit into a 1949 Schwinn. Fabricated a motor mount from a Simpson galvanized framing tee and weight room rubber flooring. Had to switch the rear hub to a Bendix to get clearance for the rear drive gear. also had to change the stock Schwinn crank to a new after market crank to gain clearance for the motor sides. I found advice here for forcing the clutch arm a few times which was really tight from setting in the box. That free'd it up to release. The intial test run worked pretty well. I made a extension rod from a coat hanger to adjust the choke from the top frame tube, saves reaching down.
I have a problem though. I have lost the carburetor idle adjustment screw. I guess I turned it out too far today and it came out on a test run. Is there an easy fix without buying an entire new carb?
Old 03-22-2009, 11:24 PM
graucho's Avatar
graucho graucho is offline
Default Re: New from Kansas
About 5 pictures down. One of the suppliers on the right.
ENGINE_KIT_PARTS_PAGE_3
Welcome home mazdaflyer. Glad your here.
Old 03-23-2009, 12:31 PM
mazdaflyer's Avatar
Thanks for the info...pretty pricey I'll probalbly get two while I'm at it
Old 03-26-2009, 11:52 PM
Dave31's Avatar
Dave31 Dave31 is offline
Welcome to the forum Mazda, glad you joined us.
