Old 03-22-2009, 09:55 AM
GoFastBicycles's Avatar
GoFastBicycles GoFastBicycles is offline
Default Oil in mag cover
Have oil in mag cover leaking out of bottom screw took cover of there was oil resting in bottom cover. Mag looks dry . Is this normal??
Old 03-22-2009, 10:01 AM
Bikeguy Joe's Avatar
Default Re: Oil in mag cover
Not really, you may have a seal leak.
How does the bike run? With a seal leak, it will tend to run lean...be careful.
Old 03-22-2009, 10:03 AM
Hard to start when it starts it dies trying to pull bike under power(stalls)
Old 03-22-2009, 10:06 AM
Yes, you have a seal leak...replace it with a new one....your seller will help you with ordering a new one, or someone here will give you a part number shortly.
Old 03-22-2009, 10:15 AM
Thanks for the speedy reply Joe.
Old 03-22-2009, 03:02 PM
MB-Monkey's Avatar
what motor is it?
Ride it like you stole it!
Old 03-22-2009, 09:25 PM
80cc from bike-engine.com
Old 03-22-2009, 10:22 PM
MB-Monkey's Avatar
here is a link to a gasket template so you can make your own.
http://motorbicycling.com/f3/69-80cc...late-6842.html
Old 03-22-2009, 11:41 PM
Venice Motor Bikes's Avatar
Venice Motor Bikes Venice Motor Bikes is online now
Custom Builder / Dealer
That's a crank case gasket... not a oil seal.
Old 03-23-2009, 02:35 AM
MB-Monkey's Avatar
doh! your right
some parts listed here
Cylinder Assembly
