Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Whizzer Motorized Bicycles
Whizzer Motorized Bicycles Whizzer motorized bicycles are still produced today, and one of the oldest motor bikes around. Share some of your stories about this timeless classic with us today
Old 03-18-2009, 05:52 PM
wadoepotatoe wadoepotatoe is offline
Default Whizzer Battery??
I've just picked up two 1999 whizzers and unfortunately they don't have their batteries. I can not get a hold of these batteries in Canada so I need some specs so I can have the local battery shop make them instead. What are the battery's dimensions? What is the Amperage? Pictures? Any other info would be greatly appreciated. Thanks in advance,
-Wade.
Old 03-20-2009, 09:56 AM
Weedylot Weedylot is offline
Angry Old Fart
Default Re: Whizzer Battery??
I had to replace mine recently. The original size wasn't available so I got one that was slightly larger. It fits in the battery box, but the cover presses tightly against the top.
The almost exact replacement is: SLA 1005 it is 1.3 Amp /hour. The original specs are available from Whizzer also.
By the way, the Whizzer doesn't like to keep the battery charged.
Hope this helps.
PS: The dimensions for the slightly larger battery are: 3 -5/8" (9.6 cm) long or wide x 1- 15/16" height (5 cm) x 1- 5/8" depth (4.5cm). The battery sits "sideways" in the battery box, its terminals face outboard.
The dimension that doesn't quite fit is the height at 1-15/16", I would suggest 1-13/16" or smaller.
PPS: If you need, I can ship two from here.
The only normal people are the ones you don't know very well.
Old 03-26-2009, 08:19 PM
Fossil's Avatar
Fossil Fossil is offline
Here you go.
I have one of these in my Whizzer. Good battery. Held a charge all winter out in the shed.
12V 1.3AH SEALED LEAD ACID BATTERY | AllElectronics.com
Jim
I didn't say it was your fault, I said I was blaming you.
EZ Motorbike Distributor / Dealer Guthriesville Pa
Old 03-26-2009, 08:43 PM
KilroyCD's Avatar
KilroyCD KilroyCD is offline
I bought a new battery from that same company. They ship quickly too.
EZ Motorbike Dealer - Quarryville, PA
http://ezmoflancaster.blogspot.com/
"That dog is about as subtle as a hand grenade in a barrel of oatmeal..."
-Foghorn Leghorn
