Bogging at low speed
My Dax 70cc.has recently developed a some serious bogging on the low end(full throttle).Its running like a champ once I get over the hump + 30mph easy 41 tooth.Can't find a noticeable leak when searching with an unlit propane torch.Compression just under 120psi.
Since I,m constantly messing with the carb I may have inadvertently altered something.Needle clip position seem to have little effect.Plug looks as usual,maybe more gray than tan but not too light
Would this more likely be caused by a rich or lean condition.I'm beginning to suspect the float position.When running warm pulling choke has little effect on the bogging condition.Full choke kills it.Any clues? Thanks,Ron
Update: I noticed today when on a steep hill and engine lugging badly,just about to die,that when I let of the throttle slightly the engine actually gained power.Ron
