Old 03-15-2009, 10:24 PM
jim p jim p is offline
Default rear sprocket installation issues
hello, i just started putting my new 66cc engine kit together. unfortuneatly, i am stumped right away. when trying to install the rear sprocket . the coaster brake hub connector(or what ever the silver metal piece that connects to the frame is called) is in the way. i cant seem to figure out how to make it work.
does anyone have any ideas??
Old 03-15-2009, 11:23 PM
TexasDav's Avatar
TexasDav TexasDav is offline
Default Re: rear sprocket installation issues
I had to bend my lever in a vice to get clearence, Describe the problem in a bit more detail and I know someone will help you out
Always do a pre-ride check. Make it a habit, and ride safe.
Old 03-16-2009, 12:36 AM
Dave31's Avatar
Dave31 Dave31 is offline
Welcome to the forum, glad you joined us.
This is very common with coaster brakes, here is a link to help you out.
http://motorbicycling.com/f3/help-sc...edal-2566.html
Well, I could not find the other links. Yes you need to bend the arm to get the clearance.
Some use flat head bolts on the sprocket and/or counter sink the bolts into the sprocket.
You may also need to trim the dust cover to allow the sprocket to fit correctly.
http://motorbicycling.com/f30/coaste...-mod-1841.html
