Old 03-13-2009, 08:47 PM
cruiserdude cruiserdude is offline
Default Best Spark Plug?
i have a 2 stroke 48cc engine, the model is Starfire Gen II . I would like to get a performance Spark plug rather then my original plug. What should i be looking for to make sure its the correct plug? Does it just have to be for 50cc motors or does a specific size, model etc matter?
Old 03-13-2009, 10:07 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Best Spark Plug?
I suggest NGK BP5HS or BP6HS. Both have extended tips.
The 49cc and 67cc all use the same basic plug size.
Old 03-14-2009, 12:21 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I like NGK & Bosch plugs... your local auto parts store can cross reference a bosch from the NGK #.
Old 03-14-2009, 07:35 PM
I got the NGK BP6hs for 1.99 since eveyone is talking about them! I figure thats the best performance one but for the price you wouldnt think that. They dont have Iridium plugs for 50cc motors? that would make a bike real fast.
Old 03-14-2009, 08:29 PM
Pablo's Avatar
There is an Iridium equivalent, I believe it's BR6HIX. But it is about $6-$7 and I doubt it will buy much.
Old 03-14-2009, 09:35 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
best spark plug to me is one that is cheap and works champion L78C or the china until it craps the bed then it takes a dirt nap.
Norman
norms-iron-works.tripod.com
Old 03-15-2009, 04:34 PM
so you suggest i replace the stock plug with the NGK BP6hs and not even bother paying for the iridium plug?
Old 03-16-2009, 02:45 AM
now i wanted to know whether i should get an upgarded CDI with my NGK BP6hs plug or not? Will i notice the difference even on my stock CDI?
Old 03-16-2009, 03:07 AM
ibcnya's Avatar
ibcnya ibcnya is offline
I run a ngk as well, i tried a bosch +4. No big difference, from the single electrode.
...ive gone to the scooter side, variators arent that bad.
Old 03-18-2009, 09:50 PM
Down_South's Avatar
Down_South Down_South is offline
If you use the stock CDI with a Iridium IX (BPR6HIX), It will be a VERY noticeable improvement over a standard plug.
The engine has a slightly higher Idle RPM and doesn't misfire as much. If you ask me, it's worth the money because the plugs have a longer service life than the standard plugs, they won't foul up easily either, which means easier starts. Give it a shot and let us know what you think.
If you hear something that sounds like angry bees in a coffee can, It's me riding my bike.
Chain:
#41 or #415
Learn About Spark Plugs
