Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 03-11-2009, 09:56 PM
Speedy Wilson's Avatar
Speedy Wilson Speedy Wilson is offline
Question Is mine too small?
I have a 22cc echo engine for a diy build. will it work? how fast will i expect to go if it does? im thinking of 26 inch mt bike.
Old 03-12-2009, 07:21 PM
Rayzor's Avatar
Rayzor Rayzor is offline
Default Re: Is mine too small?
i wouldnt expect it to hit 20, but it really depends on the gearing, the less teeth on it, the fastit goes, but the more chance the little engine will bog up and die
Old 03-12-2009, 08:37 PM
Thax for advice. I'm thinking of friction drive setup for it? Think i will get 15 mph? What size roller for a 26" tire?
Old 03-13-2009, 03:07 AM
a_dam's Avatar
a_dam a_dam is offline
At least your expectations don't sound unreasonable.
Tire size doesn't matter when using a friction drive. The torque and top speed is dependant only on the diameter of the drive roller.
I've got a 25cc Homelite motor on my 1973 Schwinn Continental 10-speed. It's got skinny 27-inch, smooth tires, and rides in a "racing" position, so that helps bring my top speed a little over 20 mph. Drive roller is 1 1/8" diameter. But the old bike is heavy (and I'm about 210 lbs), so a lighter person on a modern mnt bike might do just as well.
I have to pedal when fighting the wind or going up hills; I don't mind. I get great mileage (and need the exercise).
A 1" roller would probably give you good results.
If you have perfect efficiency (no loss due to slippage), a 7/8" roller at 6000 rpm will give you 15 mph. These little motors can definitely handle 6 grand, but they have little torque and might top out below 6000 even on level ground with no wind.
Old 03-13-2009, 10:50 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
The twenty five cc I built had great fun capacity. You can expect to pedal on hills. short steep ones, long gentle ones, but if you get good speed up going into the hill, it isn't bad at all. Even the short gentle ones can require some pedaling if you don't hit them fast. Most of the gentle ones the bike didn't slow down enough for me to catch up with the freewheel.
I now ride a 250 hub motor bike and it is very very much like the 25cc friction drive. The same pedaling characteristics. Maybe a little less top speed because it is a lower revving engine. But adequate for my needs exercise and fun.
Old 03-13-2009, 04:17 PM
Thanks for the tips...will try to locate a bike for the build. I kind of hate to take a new weed eater apart but it's in the interests of science right? Will post pics when I get some parts together,funds are very limited. I'm trying to trade a pressure washer for a bike and a few bucks.
