Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Old 03-08-2009, 03:04 PM
Midwest Autowerks Midwest Autowerks is offline
Default Starting the motor
I am looking at an 80cc motor here and I am wondering how these engines are started
it says you can do pedal starts and so on
I was thinking of removing the pedals all together here
are they pull start or is there an ignition key? I am completely noobish at this but I appreciate any and all help. thanks
Old 03-08-2009, 03:39 PM
toytime toytime is offline
Default Re: Starting the motor
You need to peddle to start but there is a pull start available for around ten bucks or so.
You also need to peddle the bike to get going with these kits unless you get a jackshaft kit from sickbikeparts. It allows you to use your rear gears but you need to keep your crank in place. I just tried this morning and I can start off in first gear without helping the bike to start off.
Why do you want to remove the peddles?
Old 03-09-2009, 12:45 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
the only time i hated my pedal start is when something was wrong with the engine. usually it was a clogged fuel line or out of gas but still it is a pain.
Old 03-09-2009, 05:38 PM
2door's Avatar
2door 2door is offline
Check your local laws pertaining to motor assisted bicycles. If you remove the pedals, bad idea, then your bike will not legally or technically be a bicycle anymore. It could fall under the heading of a motorcycle. In additon to the laws, having the option of pedaling can be a blessing in the event you have mechanical/engine problems far from home. Most will agree here; Keep the pedals.
Old 03-18-2009, 02:25 PM
I am going to keep the pedals, i bought this 80cc kit on ebay and I am wondering how a pedal start works, do you pedal then hit the yellow throttle switch to fire the motor?
Old 03-18-2009, 02:32 PM
The botton is your kill switch to turn the motor off. To start you "bump start" it.
You start to peddle and when rolling you pop the cluch and the motor starts.
It's very simple.
You may want to spend a few hours on this site; Versionate - Document sharing & collaboration, the easy way for groups to share document and files.
Old 03-18-2009, 04:16 PM
2door's Avatar
Toytime,
That is a great site. It should be required reading for every new member and even the old timers might pick up a thing or two they've forgotten over the years. It should be posted here someplace that is apparent and easily located by folks just getting started or are contemplating getting into this hobby. I copied it to 'My Favorites' for quick reference. Thanks for posting it.
Old 03-19-2009, 06:14 PM
exactly what I needed, thank you a lot one more thing....
when I look at the small sprocket that comes right off the engine, you can't turn it by hand, it is like it is in gear or something... do you just need to hook the chain up and pedal it? That is the only thing I am really unclear on, I appreciate the help
Old 03-20-2009, 05:45 AM
TigerToothBikes.com's Avatar
TigerToothBikes.com TigerToothBikes.com is offline
UK Dealer
Originally Posted by 2door View Post
Toytime,
Thats why its posted in "recommended reading" http://motorbicycling.com/f3/recomme...ding-6756.html check it out for more essential info. Hopefully an admin will make it a sticky.
For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at
www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
Old 03-20-2009, 10:11 AM
lordoflightaz's Avatar
lordoflightaz lordoflightaz is offline
When you are looking at it you have the clutch cover off so the clutch is engaged. You could use the included spark plug wrench to turn it, but by hand you just aren't strong enough. BTW that is a good way to feed the drive chain onto the sprocket, with that spark plug wrench.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
