Old 03-07-2009, 08:57 PM
dmr00000 dmr00000 is offline
Default Engine Starts but when throttles..nothing
I'm new to engines and my engine was doing great all day, but then towards the end, I shut it down, then when I tried starting it back up, it did, but when i throttled it, it sounded like a mini-rev and nothing happened...any idea's whats wrong?
Old 03-07-2009, 09:44 PM
Spunout's Avatar
Spunout Spunout is offline
MB Builder Extraordinaire
Default Re: Engine Starts but when throttles..nothing
check all your wires and intake/carb nut tightness.
and make sure your throttle cable isnt coming unscrewed from the top of carb.
is the spark plug tight?
Originally Posted by Dan View Post
sn0rk.
Originally Posted by Bikeguy Joe View Post
You are one sick man spun, I like that quality in a person.
Old 03-07-2009, 10:06 PM
i completely took apart the carb and screw everything back nice and tight, still nothing.
Old 03-07-2009, 11:26 PM
saolom saolom is offline
Smile Re: Engine Starts but when throttles..nothing
might be
choke
spark
oil fuel mix
good luck
Old 03-08-2009, 11:12 AM
Large Filipino Large Filipino is offline
Clogged exhaust.
Old 03-08-2009, 11:16 AM
Bikeguy Joe's Avatar
"Sounded like a mini-rev"? Has the throttle cable or associated parts dis-connected?
It starts and idles fine, but the throttle will give no response?
Details please.
Old 03-08-2009, 08:55 PM
Spunout's Avatar
yes...can you be alot more specific?
is the choke all the way on the 'ON' position? if so, it will start for a second or so, then might die.
sn0rk.
Old 03-08-2009, 10:32 PM
No matter what position the choke is in..nothing happens, and yes it starts..but if u stop pedaling, or the bike isn't moving, then engine just dies.
Old 03-08-2009, 11:25 PM
gofast gofast is offline
Does the engine actually start..or is it just the sound of the engine turning over due to the momentum of the bike. Sounds like it could possibly be a coil/mag problem-not firing.
Old 03-09-2009, 02:02 AM
MB-Monkey's Avatar
i agree does not sound like the motor is starting at all i would def start with making sure it sparks if you have spark and fuel then i would look for air leaks
Ride it like you stole it!
