Old 03-06-2009, 05:13 PM
flathead31coupe's Avatar
flathead31coupe flathead31coupe is offline
Default clutch adj?
what the best way to adjust a new engine installation, to be able to use the lever so it will disingage to let you ride the bike, or let it idle
Old 03-06-2009, 08:59 PM
toytime toytime is offline
Default Re: clutch adj?
It's not that hard but you need three hands.Try to get rid of all the play by pushing on the lever and then give it an extra push to account for stretching and stuff. Slide that cable end on as much as you can and tighten it up .Try the clutch and see if you are close, you may have to repeat the above again but by then you will see that you are getting somewhere. I try to use the adjuster on the clutch lever for fine tuning only because I find they are too cheap and the threads tend to strip
Old 03-06-2009, 09:12 PM
iam not following, the hand lever or clutch lever?
Old 03-06-2009, 09:14 PM
Sorry, the lever on the engine, not the hand lever.
Old 03-06-2009, 09:29 PM
so push the lever in as much as i can,and while holding it there, pull the cable through the lever and tighten up the set screw...
Old 03-06-2009, 09:34 PM
You got it!
Don't forget the spring. This is where that third hand comes in handy...lol
There will always be a little pressure on the cable, you don't want to be able to jiggle the lever at all when you are done.
You'll get it.
Old 03-06-2009, 09:48 PM
i think i see, but pushing that lever in like that wont that disingage the cluch, or cause it to slip?
Old 03-06-2009, 09:52 PM
All I'm saying is that there should be no play in the cable with a slight bit of tension. You can always adjust it again, it's not a one shot thing. You will know if it's working.
Old 03-06-2009, 09:54 PM
cool thanks....
Old 03-06-2009, 09:55 PM
How far along with your build are you?
