Old 03-31-2008, 09:17 PM
sisdavid sisdavid is offline
Default Spark plug replacement
What are the spark plugs that people have tried in these 2 stroke chinese engines. I have tried the champion cj7y, and didn't like it.
Old 03-31-2008, 09:33 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: Spark plug replacement
I think that I am running that plug or the motorcraft version it works fine for me but im not very discerning
Old 03-31-2008, 09:37 PM
Ilikeabikea's Avatar
I'm still running the stock plug. But I think a lot people here are running NGK..................
Old 03-31-2008, 10:21 PM
Pablo's Avatar
Pablo Pablo is offline
NGK B5HS works great and they are inexpensive or maybe you could try the next range cooler B6HS, but supposedly the Chinese stock plug is equivalent to the hotter B4HS...which I don't agree with....but the stock plug is slightly different than the NGK in construction and electrode tip length.
As a side note: my reckoning says a NGK BR6HIX Iridium plug would fit...not sure how it would perform.
Old 03-31-2008, 11:34 PM
paul's Avatar
paul paul is offline
Administrator
i replaced my plug and not much difference at all. the spark plug wire i changed and it made a huge difference
Old 04-01-2008, 07:16 AM
Bikeguy Joe's Avatar
Plug/wire/cap fo' sho'.
http://motorbicycling.com/f30/bicycl...-care-354.html
Old 04-01-2008, 09:40 AM
Thanks for the help I tried the Dimon fire. That is comp "forget the number" to the Champion cj7y, and I do not like the short threads. Could get carbon build up on bottom portion of spark plug threads
Old 04-01-2008, 06:40 PM
toytime toytime is offline
I am now going with a Champian L86c and I love the new sound I seem to be getting.
The plug is a bit too long and I may end up with probs. when I go to remove it but it did change the sound and feel of the bike, almost as if it is running a little richer now, from the sound of things. I have also used the "40501" which is what I seem to remember being an NGK but looking at it now, there is no "ngk" marking.
Old 05-26-2008, 05:39 PM
NGK B5HS (preferred)
Champion L86C
Autolite 4093 or 425
Old 05-26-2008, 06:03 PM
misteright1_99's Avatar
NGK B6HS Burns clean and lasts.....
