Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Lighting and Electrical
Lighting and Electrical Things that go ZOT! Ignition components, batteries, lighting and accessories for your motorized bicycle
Old 03-05-2009, 10:18 AM
wickedsickbike's Avatar
wickedsickbike wickedsickbike is offline
Default white wire powered light
does anybody have any information on a bright light to run off the white wire. where it won't reduce the spark to the plug. let it be relatively cheap and with a on/off switch.
Keep the sun in your face and the wind on your back, where ever you go. http://www.youtube.com/watch?v=BxRoePswsus
Old 03-05-2009, 10:59 AM
unraw unraw is offline
Default Re: white wire powered light
Norman sells them. Try sending him a PM.
Old 03-05-2009, 11:19 AM
schwallyjdog schwallyjdog is offline
I saw some on eBay but they looked cheaper. Price was low though.
a man is nothing without a good hobby
Old 12-16-2009, 04:41 PM
happycheapskate's Avatar
Norman's Lights look awesome and are 40 for bullet headlight (nice!) and LED tail lamp with chrome bezel.
If you are DIY type, you can visit a track lighting store and see how bright 6v 10w and 5 watt MR11 bulbs are.
I'm using 12v MR11 small lights in a PVC plumbing connector, with battery pack. These are pretty bright, but use the spot beam if you can get it or narrow flood if not. see
I do not know how much Wattage the motors can produce on the white wire, but I know that a better ground will make your lights brightest possible. These MR11 bulbs should not be run at very dim, but can dim and brighten without damage (track lighting!)
