Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 03-03-2009, 03:32 PM
toytime toytime is offline
Default What's the stupidest thing you've done on bike?
Although spending 7 hours trying to start my bike before realizing that I had crossed my CDI wires is right up there for me , today may top that.
I was getting right into changing gears today and I think that as I came to a stop sign, my rear de-railer may have been in between gears. Not sure but as I started off, my derailer got jammed and fell apart. After walking half way home I remembered that I had electric and drove home, thus , the reason for this post!
Old 03-03-2009, 03:37 PM
Bikeguy Joe's Avatar
Default Re: What's the stupidest thing you've done on bike?
I think grounding "the boys" to the gas tank when I tried to shut off my bike with the kill switch wire is the worst thing I have done.
Old 03-03-2009, 05:44 PM
Dan's Avatar
Dan Dan is offline
First build; Couldn't figure out how the tensioner worked. (I had it backwards) Tried to face clutch arm forward. Didn't check studs or use loctite. At 20 MPH, I was headed south and my motor ended up facing south/west.
I use a mallet to fit the frame to the motor and work boots to adjust the muffler if the peddles won't clear.
I want 2 ride my bicycle
Old 03-03-2009, 11:41 PM
Finfan's Avatar
Finfan Finfan is offline
While getting a headache and probably going a bit hypoglycemic I was test riding trying to figure out a noise from the rear wheel that has been a constant problem with my bike. I did a U turn on a residential street without looking first. The driver didn't have to lock up or anything but I am sure I got a well deserved cussing out.
-and-
I'm not lost, I'm exploring!
Old 03-04-2009, 12:33 AM
Rayzor's Avatar
Rayzor Rayzor is offline
spent 2 days trying to figure out what was wrong with my bike, replace and sealed all the parts i could. turned out to be the fuel valve, so just drilled a hole in it, That in turn flooded the carb and made the bowl leak, so i had to hold the tube above tank level for a couple of miles home becaue i oculdnt shut off the gas
Old 03-04-2009, 07:39 PM
...ladies's Avatar
...ladies ...ladies is offline
Hm.. Either when i had to stop the bike by pulling the spark plug off (didn't know of the choke method) and it shocked my hand, hand was numb and bleeding like crazy.. Or when i raced a a sportbike.. above 600cc... lol. It was fun
-Nick
"Those who conform, lose all ideas"
