Old 03-02-2009, 09:58 PM
Mopedamauter79's Avatar
Mopedamauter79 Mopedamauter79 is offline
Default Rough Riding at lower speeds
For some reason now in the last couple days only it's riding rough from 15 kph - 30 kph. Once It goes past 30kph it's smooths out and rides normally.. I checked everything and the engine does not appear to be loose and everything looks normal.
Old 03-03-2009, 04:48 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Rough Riding at lower speeds
It could be a number of things, but since it's running fine at high RPM's I think it must be fuel. I think you are past the break in stage, right?
If so, it could just be running rich. I would say run it hard for awhile, until it's good and hot. Then run full throttle for a minute of so on the way home, shut it off and glide in. Allow the engine to cool and look at the plug. Report back. Black dry/wet plug? Light tan? Glazed?
Old 03-04-2009, 02:29 AM
I took the spark plug cap off and looked at the spark plug and it looks normal to me. I don't have the tool to remove it and look at the end going into to the engine. What socket would do this ?
Old 03-04-2009, 06:16 AM
Pablo's Avatar
Not sure what to say. You'll need to look at the business end.
A spark plug socket (13/16"). One lousy one comes with the engine kit.
Old 03-04-2009, 08:39 AM
Bikeguy Joe's Avatar
Yep, the tool that comes with the kit will do it. Once you get it out, it should be from a chocolate brown to a (lightly) oily black.
If you've run the stock plug for awhile, you may just need a new one.
SPARK PLUG CROSS REFERENCE
About 3/4 of the way down, you'll see the NGK B5HS, or any of it's equivalent plugs....buy one from a mower shop, motorcycle store, or even SBP has them.
Old 03-04-2009, 01:15 PM
Well lucky for me I ordered one from Pablo. I have the b6 version of spark plug. I will go to Canadian Tire and see if I can find that deep socket. I will take to carb cover off and clean out the air filter again and see if that helps. The spark is only a few months old so I don't think it would be time to replace one already but then again I have started it up alot under pretty cold temp. Who knows. I'm still learning about these engines. I have learned quite abit from when I first got one.
Old 03-04-2009, 05:12 PM
UPDATE: I found the exact kinda of spark plug I needed at Canadian tire today. I also got a device made for removing spark plug's. It's called a spark plug tool and it's 13/16.
Waiting for the engine to cool down and then I will check the plug and post my findings.
Old 03-04-2009, 10:31 PM
I got the spark plug out and I put in a new one just for the sake of it. Anyway this is what the spark plug looks like that I pulled from the engine.
Old 03-05-2009, 08:47 AM
So, how does it run with the new plug?
Old 03-05-2009, 12:33 PM
I dunno yet.
