Old 03-03-2009, 02:13 PM
junkyard's Avatar
junkyard junkyard is offline
Default Re: Why not smaller chain?
dax sells a 10 tooth sprocket for the motor that lets you use reg bmx chain
make sure you get the puller tool if you dint get one with your kit
not sure about the rear sprocket....i have a custom jackshaft
Old 03-04-2009, 07:13 AM
orbit222 orbit222 is offline
Just a quick update:
I got a sram single speed chain and it fits perfectly as suggested by Whizzer Nut. It's lighter and thinner which is what I wanted. Big bonus is their master link system. It has no spring clip, you bend the chain on the master studs to get the master plate to fit. It's easy and seems bombproof.
Old 03-04-2009, 08:01 AM
toytime toytime is offline
Originally Posted by orbit222 View Post
I had a problem with power loss at high rpms. Chris helped me with trouble shooting all the usual suspects- bad mix, carb clip, etc. He's always prompt to respond. I finally figured out it was a leak in the case (see pic) which I diagnosed by spraying carb cleaner while the motor was running. I fixed it with rtf as suggested on a thread here and dropped Chris a note to tell him what was up. The motor was almost a year old at this point and he didn't hesitate to exchange it for a new one. I'll admit it was a pain, but once the problem became clear he really did come through. .
That is pretty amazing. Way to go Chris!
