Old 02-26-2009, 06:04 PM
gavmiester's Avatar
gavmiester gavmiester is offline
Angry conrod bush
Hi there ,Greetings from gold coast Australia.Any one know of a fix for the bush on an "80"measures 11mm internal 14mm external asked Zbox they sent 2 that didnt fit then said cant help!
Old 02-27-2009, 06:12 PM
Brains Brains is offline
Default Re: conrod bush
Gday gavmiester, who did you purchase the motor from?
Brains
Old 02-28-2009, 04:59 AM
wildemere wildemere is offline
Those bronze bushings will need to be honed to a press fit.
Then an oil hole is drilled and relieved.
Then honed again to accept the piston pin.
You'll need verniers or calipers at the least to do the job.
And a tool to fit the bushing.
Have you done any of this?
Old 03-01-2009, 03:11 AM
gavmiester's Avatar
Motor was purchased from Zbox, how do you hone the bush ?I did measure with electronic vernier,tried drilling out the bush but it broke up.is it possible to get a needle roller bearing to fit?11mm X 14mm
Old 04-02-2009, 07:00 PM
gavmiester's Avatar
Took the motor to local engineering shop sorted out for $20
Old 11-18-2010, 12:36 AM
gavmiester's Avatar
18mnths later the engineers work performing flawlessly,Bob Garner Engineering,races Rotax,Ducati etc
