Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 02-25-2009, 12:43 AM
Absocold Absocold is offline
Default What sprocket is best for me?
I'm on my second build and this one will be with the grubee stage II 4-stroke motor. My first build was with a china girl. I live near Minneapolis, MN thus there aren't many hills around here. I weigh a whopping 155 and will be mounting the engine on a Shwinn Jaguar from target. The sprockets I've been considering are the 41 tooth and the 36 tooth "racing sprocket." I don't care a whole lot about going fast, however it seems logical to me that running my engine consistently at lower RPMs should equal longer engine life. My biggest concern with the 36 tooth is getting up the few hills we have here in MN. Any suggestions?
Old 02-25-2009, 12:49 PM
Default Re: What sprocket is best for me?
Okay, so I read some similar posts to this and decided on the 36 tooth sprocket. But now I have another question. I want to use a fuel filter for my bike but don't know much about them. Where can I get a one which is both inexpensive and quality?
Old 02-25-2009, 01:00 PM
Retmachinist's Avatar
I get my fuel filters at Menard's in the lawn mower dept. for $2.99. You can also get them at Northern tool, or any of the home stores, Lowes, Home Depot. I don't make a habit of going to Wall Mart (Ran to many small town people out of business!) But I see on here where people get them there.
John
Old 02-25-2009, 01:05 PM
HoughMade's Avatar
HoughMade HoughMade is offline
With those sprockets, you will be pedalling a lot from a dead stop and then you wouldn't hit peak power until 40 mph or more if you have enough power to get to peak.
4 strokes with the Grubee do not usually operate with the same sprockets as 2 strokes because they make power at higher RPMs and the gear reduction through the gearbox is different. I would urge a 48 tooth to start and a 44 if you really want speed.
What may work with a 2 stroke is completely irrelevant! Likewise, what would be used with a 4 stroke and the Hoot gearbox is irrelevant. The Grubee has different gearing from that too!
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 02-25-2009, 03:14 PM
fm2200 fm2200 is offline
Hi Abso, If your just looking to get around, go with the 41. I had a 44T then put the 40T I like the 40 better, I can cruise at about 25mph. The 36T is for much higher speeds and you will have more pedaling top do, in order top save the clutch. Your weight is ideal for these gas bikes, it will be easier on your engine. You mention your not out for speed so go with the 41T good luck
Old 02-25-2009, 09:49 PM
Thank you all for the help! I called dax back and canceled the 36 tooth sprocket. He was very accommodating. Hopefully I get all of my parts soon that I can start building!
One more question. Other than making sure I grease the gear box, is there any other maintenance I should perform on the engine or parts before I run it?
