Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 02-16-2009, 07:37 PM
Fred Fred is offline
Default GxH 50cc sprocket info?
I'm looking for info about the best sprocket size to use on a Honda GXH50 build. I would like to get between 25-35 mph. Of course faster would be daring but I think in TN i'm legally allowed 20mph. Are there any charts anywhere on sprocket size vs speed? And which runs the engine at the best rpm? I thought I had read a post about this in the past, but haven't been able to find it unless it was on another site. Also this will be disc brake mounted so I hope to get one from King's.
Thanks
Fred
Old 02-16-2009, 09:23 PM
thatsdax thatsdax is offline
Default Re: GxH 50cc sprocket info?
You will need a 5:1 reduction type gear box or pulley system. And then a 10 or 11T output sprocket for 41 size chain driving a 48T rear on a 26 or 27 inch wheel will accomplish what you seek. Thanks..
visit www.thatsdax.com
Old 02-16-2009, 11:05 PM
Thanks for the info Dax.
Old 02-17-2009, 09:47 AM
HoughMade's Avatar
HoughMade HoughMade is offline
Like Dax mentioned, depends on the gearbox you use. I have a Grubee gearbox which is 3.7:1. The gearbox output is 11 teeth and the rear sprocket iis 48 teeth. I get the speeds you are talking about.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 02-17-2009, 12:45 PM
Thanks Houghmade, you have the set up i'm going for. I'm hoping to get a sprocket and top hat adaptor from Andy at King's sales and service.
