Old 10-07-2016, 02:35 PM
SpeedingTurtle SpeedingTurtle is offline
Default Re: Help
I'm buying a new magneto. Hopefully that's the solution. What could,it be,if not this?
Old 10-07-2016, 03:29 PM
Agreen's Avatar
Agreen Agreen is offline
Default Re: Help
Wires improperly connected.
Don't just buy parts! You must know someone with a multimeter? Check the resistance of the magneto. Unplug the kill switch and check from black to blue. If you have a white wire, make sure it's not touching anything. Tape it off if you have to.
Never stop wrenching
Old 10-07-2016, 03:43 PM
Default Re: Help
Sadly I don't. This one horse town I live in. I've done all this. I've checked for a spark with the kill switch in, I've checked with it out, I've switched between new and old spark plugs and new and old Cdi. Still no spark. The wire that's black looks thick at the joining point of the magneto, but the blue wire looks thin as if its been pulled. Where as the black wire looks to be about 7-8 strands of copper. The blue one looks to be about 3-4 strands of copper. But with no option of getting a solder, wire, tip, ect, I'm just...relying on a new Magneto. I prefer fixing the problem instead of prolonging it with tape and glue. If this does not work than I will figure it out. The last thing it can be without getting the spark is the magneto and it's wires.
Old 10-07-2016, 06:50 PM
crassius crassius is offline
Default Re: Help
in my experience, the smaller the town, the more likely that someone very close by fixes things and has tools
Sometimes I sets and thinks, sometimes I jes sets.
Old 10-07-2016, 06:52 PM
Default Re: Help
Thank you for the assistance, and feedback. I will try and find someone with the tools as well just in case.
Old 10-07-2016, 08:29 PM
kevyleven007's Avatar
kevyleven007 kevyleven007 is offline
Default Re: Help
I twisted the wires together and wrapped them in electrical tape(duck automotive electric tape) and my bikes all started and ran great. One of them I didn't even have to pedal just give a little push with your feet and hit the clutch. just sayin
peace.
Old 10-07-2016, 09:11 PM
Tyler6357's Avatar
Tyler6357 Tyler6357 is offline
Default Re: Help
If you have a meter you might check the coil and see if you are getting anything out of it. Those coils can sometimes fail, they are cheap and easy to replace.
Old 10-08-2016, 05:37 AM
ZipTie's Avatar
ZipTie ZipTie is offline
Default Re: Help
Just another thing to double check...Your wire in the spark plug cap may not be touching the spark plug tip. This is also a common issue with these kits, I've seen this twice where the cap guts are badly twisted and buried 1/8 " from the plug tip. Thus wreaking the spark. Take a flashlight and look inside the cap to be sure the wire ring inside is located properly
Where it snaps onto the plug top. Also some plug tops have an adapter for a bigger cap wire loop and some smaller wire loops need that plug top Adapter taken off. It's very inconsistent.
"One pull and It's on, one snip and its off"
“Lets not get too technical”
Old 10-08-2016, 08:03 AM
Agreen's Avatar
Default Re: Help
I think you're misunderstanding what I'm saying about improper connections. Sure, twisting and taping is not the way to go, but it'll work for at least a little while.
What I'm asking is how is it connected? Pictures of connection points with a brief description?
MotorBicycling.com
