Old 10-05-2016, 11:16 PM
TheSignGuy TheSignGuy is offline
Default face palm hp to cc help
Having a issue I here that 13 to 17 cc equals 1hp,
I found a numerous amount of good engines 3hp, but on some it says 97cc is that necessarily true for a thick shafted engine I'm not looking to get pulled over, nor am I looking to buy a beat up pocket bike I want a thick shaft for heavy duty usage on the road rebuilding my chopper but must be in compliance with law.
The law shall not be evaded I concerned debadging the serial and purchasing a briggs sticker of lower cc but that's not excusable. Ehhh
It's NOT what you Can't DO Its About What YOU Can build.
-Harley and Davison.
Old 10-06-2016, 10:50 AM
Agreen's Avatar
Agreen Agreen is offline
Default Re: face palm hp to cc help
There is no such cc to hp rule. There are 30 hp 212 predators oUT there. They come stock at 6.5 hp.
I don't know what the laws are in Washington, so it's hard to determine how to help. Look up the power rating on the HF website and see what it says for the 79. I'm pretty sure 3hp sounds right though. If the size is a concern, find yourself a 50cc sticker for the flywheel cover.
Never stop wrenching
Old 10-06-2016, 10:58 AM
Says no more then 50cc must be read as 49cc if it's 50cc exact they split hairs to control the aware.
Other laws include it must be 2bhp I just don't want my rig doing 45 if I do 20 I won't be bothered 30 questionable but law permits up to 30 mph on mopeds.
We are concidered a gray area it's still a bicycle with pedal delete I'm adding the pedals back from a little girls bike that I know that broke down chop off specialized crank. Instead of spoke driven both sides will be rim driven also is there a way to weld aluminium rims chopper rims are ridged in the middle over time they split down the sides.
As for the specialized frame I decided to invest in this moped motor 125 cc and make the specialized a drag bike for kids. Fast as **** but hey its so low they won't be able to wheelie.
Irony is i found a guy who's selling a x7 pocket bike soul jabbing for his throttle and engine with exhaust but it says online that the x7 crotch rocket engines 49cc but 5.95hp?!! Your F * kidding me right?
Old 10-06-2016, 11:16 AM
curtisfox curtisfox is offline
http://www.minipocketrockets.com/x7-super-pocket-bike/
This says 5.1 hp, a good tuned engine will get that. But if it says 49cc there is now way a cop will know the Hp, as for most they around 2hp............Curt
Old 10-06-2016, 11:26 AM
KCvale KCvale is offline
Legal in AZ is 48cc so that's what all my gas engines are ;-}
They have a badge to prove it ;-}
KC's Krusiers Builds
Old 10-06-2016, 11:33 AM
So shall I go with a go kart motor or a pocket bike x7 which matches exactly, my rear wheels welded on at the axle hub gear so thus making it easier to snap a pocket shaft from laying off the throttle, the first build "lambi" was a friction drive shaft with a bowlens 50cc that threw the shaft. After pedaling when i laid off the throttle the shaft snapped going up hill. Wish to avoid tiny shafts.
Old 10-06-2016, 01:01 PM
Agreen's Avatar
Sounds like sc laws. 25 mph limit, but can't be physically capable of going faster than 30 on a flat surface. Must be 50cc or less. I have no issues with taking off and getting up to speed with my 48cc and centrifugal clutch kit. I have, however, considered making it a hybrid with a 48v electric front wheel with some small batteries to be used for takeoff only. No laws say I can't. May be worth a look...
Edit:
I also snapped a shaft on a weed trimmer FD. It was a 23cc weedeater engine with a 7/8" socket bolted to the crank. The crankshaft flew off and the flywheel went whizzing by my ear. The stress on the crank with friction drive is too much. A better way is to run bearings on both sides of the roller (like staton friction drives )
Old 10-13-2016, 06:01 PM
Edit:
HAHA! burrrrr RAHHHH! #FROOM# dO,ob (===)
LOL well mine just looked like a grown man ran up and snatched it off and said walk home.
Hey what do you think of these motors? This is more along the lines of what I need.
http://www.ebay.com/itm/like/1811168...D1109113757447
Old 10-13-2016, 06:31 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Yeah, ratio of hp to cc is a very variable thing. Right now, That'sDax has a KTMC 2-stroke that is stated to put out 9 hp at 12,000 RPM. Nine horse from 49 cc. That would curl your hair a bit.
So many things about an engine influence horsepower, like backpressure, air-fuel mix, air temperature, size of carburettor venturi, octane rating, proper spark, and so on.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 10-13-2016, 06:33 PM
Agreen's Avatar
I've heard terrible things about those CAG engines. I have zero first hand experience with them though, so take it as you will.
Definitely doable. There's a few people who have done it before.
MotorBicycling.com
