Old 09-25-2016, 09:33 PM
Press718 Press718 is offline
Default Re: 4 stroke huasheng bicycle engine loss of power
Thanks for the in for im going to be buy a cdi in a few days i did know there were 2 different types of cdi for the 4 stroke engine thanks for that in put i will let u guys know what happens when i get it..
Old 10-06-2016, 03:38 PM
I have a little problem with Spooky Tooth cycle not with the name itself but with an employee there I had ordered a part 4 my motorbike in the part where you make your order I had put in my address and it automatically put in my old address as well to make a long story short right when I was in the order area I pressed to proceed and I noticed after I pressed that there were two different addresses so I called Spooky Tooth cycle immediately I got through to someone finally explained my situation as far as the addresses goes the person told me that he would take care of it he didn't I had a big issue with the post office trying to explain to them about the addresses on my order and was given the runaround finally after 2 days I finally got the order so my advice to people that order from Spooky Tooth Cycles make sure you get your information right because they're not going to correct it for you.....bad business.
Old 10-07-2016, 05:51 AM
bluck bluck is offline
Did you ever end up getting your 4 stroke working? Was it the cdi or gearing? just curios
Old 10-09-2016, 02:19 PM
scotto-'s Avatar
scotto- scotto- is offline
Custom 4-Stroke Bike Builder
Smile Re: 4 stroke huasheng bicycle engine loss of power
It sounds like a combination of to tall of gearing and carburetor issues. I would suggest running at least a 48t rear sprocket. A 50 tooth would probably work better.
It could possibly be the CDI.....check the air gap, connections and make sure it's bolted on tight.
I'm thinking the carb needs to be dialed in. Check the throttle cable also and make sure it has full range from idle to full, adjust if necessary.
EZ Motorbike Dealer - San Diego, CA.
http://www.ezmotorbike.com/
Nothing is out of my realm,
if it doesn't fit, make it fit! Beer is the answer....what was the question?
A sense of humor costs nothing, why don't people use them more often?
"You can't buy respect.....you have to earn it"
Old 10-10-2016, 12:01 PM
whats up guys i want to thank all of the input u guys gave me sorry i didn't get back to you guys sooner but im in florid and we had hurricane mattew come by for a unwanted visit. just starting to get things back to gather i did put the new cdi on the motor and still having the same problem so im going to order a cabr now and see what happens and buy any chance does anyone know the correct value setting for the huasheng engine. thanks again guys ride safe
(Press)
Old 10-10-2016, 12:04 PM
thanks im thinking the carb i will let u know what happen in a few weeks ride safe
(Press)
MotorBicycling.com
