Old 09-16-2016, 10:02 AM
Slugo777's Avatar
Slugo777 Slugo777 is offline
Default Slugo 4inch 80cc help!!!
Names Aaron Inlive in North East Tennessee, I've got my slugo fully built and all together and then I realize... the chain will not clear the tire... I'm using an 80cc 2 stroke engine but I have no idea what to do now, I have so much money tied up in this dang bicycle and now I can't even ride it....
Does anyone know if they make or sell a conversion kit to fit an 80cc 2 stroke onto a micargi slugo one speed?
Old 09-16-2016, 10:34 AM
Slogger Slogger is offline
Default Re: Slugo 4inch 80cc help!!!
I put some mildly fat tires on my walmart onex and had to find a special skinny chain to make them work.
I hate to be the bearer of bad news, but..
With those 4" fatties, you either need a jackshaft or an offset engine mounting setup.
Buzz zzzzz zzz
Old 09-16-2016, 10:50 AM
ZipTie's Avatar
ZipTie ZipTie is offline
Welcome to the forum, Call Lynn at this web site, I'm about positive she will have what you need to get you on the road.
http://custommotoredbicycles.com/
Zip
"One pull and It's on, one snip and its off"
“Lets not get too technical”
Old 09-16-2016, 10:58 AM
Picture two small sprockets, almost side by side on a shaft, supported by two bearings on a 'U' shaped bracket welded to the seat tube, sticking out to the left.
The engine chain on the inner one, the drive chain to the rear on the outer.
I think this would be the easiest fix for a fat tire.
Offsetting the engine past the frame tube would be too much anyhow.
Some motorbike supply company might make some money selling that fat offset jackshaft. Lots of fatbikes out there now.
It will rob a little power, but it lets the fat tire be used.
Buzz zzzzz zzz
Old 09-16-2016, 11:51 AM
TheNecromancer13 TheNecromancer13 is offline
If you used steel plates and U bolts to make your own mounting hardware, you could shift your engine over just a little bit provided your engine isn't a super tight fit inside the frame.
Old 09-16-2016, 12:07 PM
Absolutely. If you had a small diameter down tube you might even grind out the fishmouth part of the cases and shim it over for all the clearance needed. Need those thin tubes, though.
I think my tire was 65 mm, and it was a problem. It balloons up bigger than that.
There is a kind of chain, like 415-I or H ? that is strong but narrow.
That's how I got around it.
Hey, the tube could be cut out at the strategic spot, replaced with welded in, off center smaller tube and problem solved.
Frame might be weakened but that stops noone around here.
Buzz zzzzz zzz
Old 09-16-2016, 02:57 PM
mogollonmonster's Avatar
mogollonmonster mogollonmonster is offline
I'm with ZipTie, call Lynn.
Old 12-09-2016, 12:34 AM
Dooley Dooley is offline
I am going to end up building this bike and would like to know did they have a offset mount? And were there any other things you needed? Thanks
MotorBicycling.com
