Old 08-27-2016, 02:20 PM
stars stars is offline
Default Bearing ball stuck
i can't start the engine because the bearing ball is so far back & is stuck. i need to remove the bearing ball so i can replace & lube up. any ideals how to remove or loosing up the bearing ball?
Old 08-27-2016, 04:08 PM
Chaz's Avatar
Chaz Chaz is offline
Default Re: Bearing ball stuck
Penetrating oil like wd40 and patience. If it were me, I would also try a bit of gentle tapping with something not too pointy. Last resort would be heat but don't blow yourself up. Maybe a soldering iron.
prepare for the ball to shoot out and play hide and seek with you.
Just a chimp with a gun and an idea we should be free to ride our machines without gettin hassled by the Man.
Old 08-27-2016, 07:56 PM
crassius crassius is offline
take off rotor and put bucking bar on it, put bucking bar in shaft and remove gently, ball should be stuck to it
never had to remove one that was causing a problem though, and don't see how it could cause a problem
if rusted in, tapping a loosened flower nut on other side may shoot it out
Sometimes I sets and thinks, sometimes I jes sets.
Old 08-28-2016, 02:51 AM
Tyler6357's Avatar
Tyler6357 Tyler6357 is offline
Try using a magnet---these work good--> http://www.ebay.com/itm/New-Portable...oAAOSwKrhVZWJm
Old 08-28-2016, 10:11 AM
Venice Motor Bikes's Avatar
Why not just leave the bearing & pack some grease in there (& only replace the bucking bar)?
That bearing should still be in perfect condition.
Follow VMB on facebook>>> facebook.com/VeniceMotorBikes
Follow VMB on Instagram>>> instagram.com/venicemotorbikes
Old 08-30-2016, 04:49 PM
QuietRiot522's Avatar
QuietRiot522 QuietRiot522 is offline
Maybe you can pop it out with a shot of compressed air? If you have an air compressor around.
Old 09-03-2016, 01:25 AM
mogollonmonster's Avatar
mogollonmonster mogollonmonster is offline
What crassious said. If your engine is anywhere near new, your clutch needs adjustment anyway, so there lol. These kits engine has an awesome clutch system, it's just a little finicky. Once you get it dialed in, daily wheelies will blow a motor before wearing, let alone shredding, your clutch. Just don't lube it! Grease the gears, not the clutch. If you do accidentally grease any part of the clutch itself, brake cleaner, lots of it. Not only does it make your clutch slip immediately(duh) it degrades the pads (in my opinion/experience), making them prone to slippage forever.
I'm not 100% positive the above clutch degradation theory is correct, but it's what I've observed.
MotorBicycling.com
