Old 02-15-2009, 12:01 PM
MB-Monkey's Avatar
Default Trickle Charge White Wire?
Was poking around Alibaba and found a description I did not understand.
Magneto
Primary Voltage Generator "Magneto". This coil provides voltage for spark, a trickle charge, and trigger for CDI igniter coil unit.
Now i know what the Mag is and what it does but I am assuming the "trickle Charge" they are speaking of would be the white wire.
What would it take to use the white wire to charge a 6V Battery? As i understand things the white wire puts out roughly 7 volts and 3 watts. that would seem to be enough voltage to keep a 6v charged.
I also believe there is AC not DC at the wire how much of an issue would that make?
Ride it like you stole it!
Old 02-16-2009, 01:18 AM
biken stins biken stins is offline
Default Re: Trickle Charge White Wire?
Think it could over charge the battery. Something would be needed to stop it when fully charged. The volts seem to very from post to post. Wonder if a 6v volt regulator would work ?
Old 02-16-2009, 04:32 AM
brisbane_boy's Avatar
brisbane_boy brisbane_boy is offline
u could use a diode to stop the power going from the battrey to the engine. , once the batttrey is full it just wont accept the charge.
who needs a car wen u can have a motor bicycle
Old 02-16-2009, 01:29 PM
HoughMade's Avatar
HoughMade HoughMade is offline
You need to convert it is DC- as it is produced, it os AC.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 02-16-2009, 03:45 PM
Are the bulbs that work off the white wire AC ? Or is it a volt or watt thing ? I use a headlight bulb from a generator on wheel type. It works ok to be seen. Can't use another for tail light as engine dies. what the heck, just like brakes there over rated. We have small shiny reflectors.
Old 02-16-2009, 03:55 PM
2door's Avatar
2door 2door is offline
Biken,
Light bulbs don't care; they're ac/dc...like some people I know. If you use the white wire to power a lamp you must use 2 wires and one grounded to the engine block or to the frame if the engine is not isolated from the frame by rubber, paint, etc. If the white wire goes to ground (engine, frame) it will kill your ignition, same as a kill button. Same thing will happen if the bulb shorts out internally; don't laugh, I've seen it happen too many times.
Old 02-16-2009, 03:59 PM
2door's Avatar
Briz,
Sorry but I disagree. A battery can be overcharged unless the charging source has a voltage regulator built in that shuts off the current when a set voltage is reached. Some older chargers did not have this feature and would cook a battery if left on and forgotten. A defective voltage regulator in a car or a car's alternator will also kill a battery by overcharging it.
Old 02-16-2009, 04:52 PM
oldcliff oldcliff is offline
I just posted my fix on the thread but my computer bumped me off line BUMMER!
Here goes a posting second try.
First of I am a retired electrical engineer with 35years in the machine tool industry.
Charging circuits aer not my field, but i will try to explain without too many complications. Because of getting bumped off I will do it with two posts. the first being charging circuits in general and the second being my suggested fix.
First post, description of charging circuits.
Auto charging circuits come in two main catagories. # 1 is the altanator that use a bridge diode network to regulate the voltage and amperage. #2 type is the generator that uses coils with breakers to regulate the voltage/current. Because the Chinese use a magneto the above two circuits probably wouldn,t work well for us.
In my next post I will explain my Model T tyep charging circuit
Oldcliff
Old 02-16-2009, 05:36 PM
As I suspected the second post didn't go through. I got bumped of AGAIN!
Here goes for try no 3.
Second post The model T Charging system.
My model T has a magnito just like th Chinese bikes. This is not compatable with the altinator or the generator/regulator charging circuits.
To solve this battery charging problem in my model T which has a battery and no onboard charging systim I came up with the following circuit It really works.
The circuit consists of a diode and a 6 volt tungsten filaimat light bulb in series with the magnito and the battery. I used a 6 volt auto dome light and a diode rated at 24v piv.
The diode is connected to the magnito with the arrow pointing AWAY from the magnito. The light bulb is connected to the diode and to the battery. When the rpms go up and the voltage gets higher the bulb gets brighter regulating the current. the diode acts as a half wave regulator which makes the voltage look dc to the battery.
Because I keep getting bumped off I will end this thread for now. any questions, please feel free to ask
Oldcliff
Old 02-17-2009, 10:24 AM
jasonh's Avatar
jasonh jasonh is offline
If you're using a sealed battery (SLA, AGM, etc) you'll want some type of charging control. If you are using a flooded lead-acid battery, overcharging will result in the acid gassing off. Not a terribly big deal, except those fumes are dangerous and you shouldn't breathe them, and I believe they are flammable. So yeah, pretty much screwed there.
