Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 02-14-2009, 11:28 PM
glacknoid's Avatar
glacknoid glacknoid is offline
Default honda 50cc governor
Has anyone with a honda 4 stroke 50 cc kept the governor parts in tact but replace the spring from the throttle lever to the governor arm with a stiffer spring or rigid wire to prevent the governor from slowing the motor down during acceloration yet allowing an easy start when the governor is in the settled possition before starting the motor also allowing for an easier throttle hook up useing the conduit clip and swivel stop parts from staton inc.
Untitled Document
Last edited by glacknoid; 02-14-2009 at 11:34 PM. Reason: forgot to add photo link
Old 02-16-2009, 10:21 PM
thatsdax thatsdax is offline
Default Re: honda 50cc governor
You can replace the stock Honda Carb with the Titan carb and this will do away with the Governor. Also.. The Titan Carb will have a throttle cable stop with adjuster. This will give you all the Throttle control you need. Go to bicycle engine kit, bike engine, bicycle engine, bicycle motor and parts page 1 or 2. You will find the Titan carb there. Cost is only around 29usd. Thanks.. Enjoy the ride...
visit www.thatsdax.com
Old 02-17-2009, 08:00 AM
glacknoid's Avatar
Thanks thatsdax it looks like the HS carb only 10 $ cheaper.
Old 03-20-2009, 03:18 AM
Dan's Avatar
Dan Dan is offline
Hi Glacknoid. I am just finishing up my first Honda build. (The throttle is a big pain) I was going to try what you are thinking, but thought it better to lose it all together so as to have complete control. I just kept thinking that it would "feel" the need to govern more gas when applying brakes. From what I have read, it is possible to keep the gov., I just do not know from personal experience if it is wise
Hough made gave me some great advise about just this and ways around the other challenges. His advice is well worth the read.
http://motorbicycling.com/f37/new-ho...html#post67519
Please keep us updated on your build. ..and lots of pics
TC
Houg's ride. How cool is this!? Gallery: Homemade Motorized Bike Pays Tribute to Motorcycles of Yesteryear
I want 2 ride my bicycle
Old 03-20-2009, 07:55 AM
glacknoid's Avatar
Dan: I put the titan carbs on both my bikes. It works well. I like it better than with that pesky gov. I'll get some better photo's this summer to post. Hopefully both will be complete with jackshaft shift kit and all. I was even checking out the NuVinci cvt hub but I'll have to do more research to see if it's worth the money. Were talking 350 for the parts.
Old 03-20-2009, 08:25 AM
Dan's Avatar
Dan Dan is offline
Very cool Glacknoid. When I was pulling my hair out with the dang thing, I wish I had known Dax's carbs would work. I couldn't find any HS's. Glad they worked for you. I ended up moding the cable to also work as the return tension. Works really well (so far) I also really wanted to keep it stock. Most folks seem to replace the carb and swear by em so I will try on a future build
NuVinci cvt hub, sweet. I saw one recently on Clist and was tempted. If it works well and lasts, would be worth it.
(Wonder if you could mod it to work as a MB auto tranny. mount it it between the engine and rear wheel, then jack shaft to the right with a sprocket bolted on the left driving the rear wheel sprocket...? Gonna thunk about this one)
