Old 02-12-2009, 10:11 AM
Graham Graham is offline
Default Chain Breaker alternative
So here I am about to get my bike back on the road and the only thing holding me back is properly installing and tensioning my bike chain. There are park tools out there that would make such a feat but a trifle, but not when you dont have $40 to drop on one. are there any chain instilation suggestions for someone on a tight budget?
Old 02-12-2009, 10:23 AM
spad4me's Avatar
spad4me spad4me is offline
Default Re: Chain Breaker alternative
Hugh Made says it clearly
...but a punch and hammer works fine. I never grind the end of a pin. If you do, it may not hold well if you try to reuse it....which often happens. To use a punch, just put the link up on an old small socket so the pins has somewhere to go, put the punch on the pin, and drive it out.
Spad here I grind to shorten a chain.
Old 02-12-2009, 11:13 AM
...ladies's Avatar
...ladies ...ladies is offline
Definitely just don't even use the pulley. Just shorten the chain and pull the wheel back tight. Works perfect..
-Nick
"Those who conform, lose all ideas"
Old 02-12-2009, 12:01 PM
Pablo's Avatar
Pablo Pablo is offline
$12.95 for a SBP chain breaker
Old 02-12-2009, 12:05 PM
wait, I dont even need to use the the chain tensioner?
Old 02-12-2009, 02:23 PM
toytime toytime is offline
Not if the chain makes it by the frame and you can slide your wheel backwards to adjust the chain. On some bikes the chain stay gets in the way and washers can be used on the rear axle to spread the frame apart a little.
I just use vice grips to press the pin until it is even with the link and go the punch route. Just put a nut under the pin to give the pin room to exit on the backside. Do not grind the pin, they look mushroomed but they are not. I also install the pin with vice grips.
