Old 02-11-2009, 05:13 PM
Nerevar Nerevar is offline
Exclamation Spark Problems
I recently determined my CDI [I]and[I] magneto were bad so I replaced both. Now with the replacement parts installed I only have spark with the plug out while i'm holding the plug... which shocks me mind you... HELP PLEASE!!!
Old 02-12-2009, 12:26 AM
biken stins biken stins is offline
Default Re: Spark Problems
If your getting bit when it's out, should mean it is sparking in engine. Did you change plug and wire ? Wire may have a break in it when positioned different. Is is getting fuel. What kind of engine ?
Hang in there.
Old 02-12-2009, 09:50 AM
spad4me's Avatar
spad4me spad4me is offline
How did you determine the cdi was bad?
Do not allow the plug to spark ungrounded.
With the sparkplug wire connected to the plug. Firmly press the threaded part to the bare metal cooling fin while watching the spark plugs GAP. Now let the clutch out. Gently push the bike forward. Did you see a spark??? Keep trying until you either see a spark or you are sure you did NOT .
You will probably wind up buying another cdi.
Old 02-12-2009, 12:12 PM
Pablo's Avatar
Pablo Pablo is offline
What plug and wire?
Old 02-12-2009, 08:07 PM
Hang in there.
Yeah i purchased a high performance plug and wire. It is getting fuel... I can smell it when i push the bike with the plug out. It is an 80cc Chinese engine from BoyGoFast.
Old 02-12-2009, 08:12 PM
I tested the CDI and magneto with a meter and compared them with readings people got on this forum. I got open for all readings concerning the blue wire on both the CDI and magneto. Which would mean that they're both bad. I got back from work late today so I was unable to try your idea. If I don't get a spark does that mean the brand new CDI is bad? When it sparks while i'm touching the threaded part of the plug, my left hand which is holding the handlebar sometimes also gets shocked. I'm puzzled. I have the black wire of the magneto on the lower left screw that holds it in... is that correct?
Old 02-12-2009, 08:29 PM
toytime toytime is offline
Seeing as you have the same problem as you began with, I would be asking myself if it was something else right from the start. Wiring?
Old 02-13-2009, 10:23 AM
Bikeguy Joe's Avatar
If you are getting spark while grounding yourself to the bike, you are getting spark while the plug is screwed in.....
Old 02-14-2009, 02:50 PM
Thanks for the help everyone I finally got it up and running yesterday. Only thing now is it runs kinda rough at full throttle - seems like it bogs down. Any ideas?
Old 02-14-2009, 04:57 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
is it running a little rich? mainjet size might be too big.
norms-iron-works.tripod.com
