Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Old 04-15-2016, 09:58 PM
curtisfox curtisfox is offline
Default Re: rear suspension #2
Check out Mr.B's http://motorbicycling.com/showthread.............Curt
Old 04-15-2016, 10:40 PM
scratchbuilder's Avatar
scratchbuilder scratchbuilder is offline
Hey thx Curt..check'd it out..i cant tell how it works...my fault..i found in the Search..harry76, and what he's done might be the idea..i'll want to pull back to engage.. then if need be have it so i could 'knee slap it' to dis-engage..reason i'm thinking this way is that i want single brake levers for more stopping power. The dual is fine for 20 mph...
Old 04-16-2016, 06:52 AM
cannonball2's Avatar
cannonball2 cannonball2 is offline
I have found shudder on take of with a cent clutch to be too high a ratio. Whats the ratio?
I have a dual pull brake made by Sunlite. The initial set up is critical. It pulls differentially. one begins before the other. I guess maybe to bias the rear brake first(depends on where you put the cables). Play around with it a bit. Mine worked pretty well on the 49cc shifter which topped around 35. If you want massive pull use the M/C handles.
One would make a great clutch handle also. I used a clamp used to hold 1/2" water pipe to make a fixture to hold the clutch disengaged. Might work for you.
Sorry about the pic but you get the idea.
Old 04-16-2016, 09:12 AM
Yeah my dual pull is from sbp. Im just going through the disapointment phase...
Old 04-16-2016, 12:41 PM
Well..i had this clutch in the box. Its 3/4 and the bell runs on a bushing..and its old and the shoes are broken in a couple spots on the edges. (pic). Best of all its Fibre shoes. Which is what i searched for and could only find a 1"...anywho it works good still and the horrible shudder take offs are gone! So my disappointment is the wasted money on the metal cotton'pickin shoe clutches. Does it help to drill holes in the shoes....im thinking faster engagement??? So the bike runs good...going for a ride to a bike shop..the guy does 2stroke mb...going fully dressed on a shake down run
Old 04-19-2016, 03:46 PM
I put a new bushing in this clutch (pic above) and keep sanding the dark spots on the shoes after a run around the block..to get them to engage across the whole shoe..its working nicely. Sooo imove the engine set up to my Del Rio and put lil hs142 on the self. Anyone got experience with Draggin Skins clutch?? They have fibre shoes!
Old 04-22-2016, 02:25 PM
Briggs back in. I'll weld in a mm at the angle neeed ,enlarge the original mm holes in front to be able to get bolts up to the angled mm. This way i can get a carb and filter on.
Old 04-23-2016, 07:24 AM
This is one of those builds that puts you thru the creative wringer. Looks like you will wind up with a really nice ride when finished. The rear suspension is impressive, looks factory.
Maybe keep this one?
Guess you could be like me and keep em all. They eventually become mobile part storage fixtures for future builds. Rolling recyclers so to speak. I guess that's part of the fun/sickness of my hobby with these things.
Inshore fishing is starting up so guess all of em will be dust collectors for a while.
Old 04-23-2016, 12:06 PM
Yeah.. Lol..my thought exactly..yeah no more selling...im not comfortable doing that. I did it just to keep building the perfect one... beginning to know ..that aint gonna happen..lol..having put the g100 on Del Rio, ive got the power now to climb any hill by just rollin on the throttle. So i'm gonna just go slow with 'whittie'.Um..looks like i need to heatthe manifold and level out my carb..
Old 05-23-2016, 06:12 PM
Well back at it..cut off the old mm plate out and got a new one going..1 1/2 lower and 2" longer. Now, i can get my pz19 fitted. Because the old mm had the engine shaft 2" above the js at a 30 pull up it would bounce up and down on take off, combined with a little clutch chatter...it was wild. Now i can keep the same tank and mount.
MotorBicycling.com
