Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop
Motorized Bicycle Welding, Fabrication and Painting - The Chop Shop Custom fabrication and projects, tanks, frames and more.
Old 03-14-2016, 01:53 PM
scratchbuilder's Avatar
scratchbuilder scratchbuilder is offline
Default rear suspension #2
The beginnings of a new rear suspension build. I think this is a better looking front clip than the cruiser frame. I'm going to use short cranks to keep it low.
Old 03-14-2016, 06:11 PM
Tony01's Avatar
Tony01 Tony01 is offline
Default Re: rear suspension #2
Yeeehaw!! This is going to be a sweet build can't wait to see it done.
I don't always listen to Alice in Chains..... but when I do, SO DO THE NEIGHBORS
MxTrq clutch tuning | msrfan 2spd | 212cc 2spd | 3.5hp 2spd | Thud 2spd | CVT tuning
Old 03-14-2016, 07:42 PM
Me too..this one got a lot of welding. This one is staying. That last Briggs made a believer out of me... So as the addiction grows I couldn't say no to 5, five Briggs for 5$ each!! No carbs....idk....3 have spark..2 no mag/coils. I'm gonna run the center pivot on the girder through the seat tube. Less brackets to make. And its place's the shock at a good place for engine clearance.thx 01..
Old 03-14-2016, 09:26 PM
magna_503 magna_503 is offline
I thought the v2100 was an aluminum frame, and not steel. I guess the swing arm is steel???
Old 03-14-2016, 10:28 PM
The v21 is alum. what i do is use a steel donor dual suspension and cut tthe bb with the swingarm mounts out of the bike and weld the mounts to my frame..in the thread 'rear suspension' there are pics of how i did that marriage.
Old 03-18-2016, 06:26 PM
Motor mount going in. Cutting into the down tube worked well on the last build...sooo, doing the mm this way gives 1 1/2 more space for js. A pic of spare parts and next in line. The 3.5 hp has a short 3/4 shaft if i use it id have to do a js clutch. Ordered gaskets and rings for the engine im using now(3hp).
Old 03-18-2016, 10:02 PM
curtisfox curtisfox is offline
Looks like a lot of Briggs powered bikes coming, Looking good ..............Curt
Old 03-19-2016, 09:48 AM
cannonball2's Avatar
cannonball2 cannonball2 is offline
Wow this is killer! A wild man with a welder!
You gonna run the same type of carb?
Old 03-19-2016, 03:38 PM
Lol.. Ive got a helmet sticker with a crazed looking dude saying..."must weld". Tried to order bearing hangers ....not..BMI had em... 3$.... and only 13$ shipping..say what...got the wide bb & parts coming from Sbp. So a pic of my js carrier. I got a pz16 coming, i was gonna use on the honda. Ill try it . just for info. Hey my honda wont run right..when you hold the thottle at an rpm you want..it revs up..revs down..revs up ..revs down. Ive removed all gov. from inside...idk...
Old 03-19-2016, 03:40 PM
Thx curt..gonna take a lot of make-up to purty up my welds.
MotorBicycling.com
