Hi
I've never had to take the cylinder off, I'm having a minor leak around the base. You can feel a small, hot draft when you put your hand near the case/cylinder. Engine is a 66cc CG and has about 450 miles on it.
Stock with a long manifold and slightly modded muffler.
It was fine one day, then it wasn't. It lost some power and about 5 mph on top.
Hard to start and just doesn't pull like it was.
Today it ran better, but still not up to snuff.
Anywho, I want to call Duane at DAX and put a new base gasket on.
Now the question- If I take it off and carefully reinstall it, do I need to replace anything, like the rings for instance, to get it to run like before?
Maybe I should tear it down before calling Duane, to see if anything else might need replaced while I'm in there. Or maybe the old gasket with a coat of permatex hi temp seal would be a cheaper fix..
Thanks for any responses ahead of time.
Slogger
Slogger
