Old 02-07-2009, 12:00 PM
philymitch's Avatar
philymitch philymitch is offline
Default anyone ever used rubber motor mounts
I am a newbie to motor bicycling and think I stumbled across something. Has any one ever used rubber motor mounts. The reason I ask is the other day I was out on a ride and one of my motor came loose, my motor had lots more power and the screech went away and at wot the hesitation was gone seamed to help a lot of things is there any info or a thread on this.
Old 02-07-2009, 12:07 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: anyone ever used rubber motor mounts
Yes, there are threads on this if you look around here...
Old 02-07-2009, 03:37 PM
Dave31's Avatar
Dave31 Dave31 is offline
http://motorbicycling.com/f6/rubber-mount-4146.html
A lot of the links in this thread discuss rubber mounts
http://motorbicycling.com/f34/vibrat...lems-5923.html
Old 02-07-2009, 08:28 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
you say that when your motor mounts came loose your bike ran better? with the motor mounts tight is your chain tight? your chain should have about 1" of slack a little more or less but do not try to run the chain like a bow string as in tight as jell if you know what I mean.
norms-iron-works.tripod.com
