Old 09-20-2015, 03:05 PM
inspectorcritic inspectorcritic is offline
Default Would it work if I ...
Could I reinforce my back carrier drop the engine on it strap it down use full thread bolt on the drive shaft put a couple of stop nuts on it center in a rubber wheel to the rim bind it in with a wing nut and use that for a friction drivr snd don't half to miss around with heavey channel and parts to make it go horzontal?
Will cause fatigue on the shaft and wigle it to death?
Can I use a used lawnmore engine save money is there enough torge?
Old 09-20-2015, 05:40 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Would it work if I ...
give it a shot if you want, but honestly using the rim as a surface for a friction drive isnt likely gonna be a good idea.
Even knurled rollers pressed down on the tire will slip under some conditions so I dont see any way to drive the rim and make that work.
