Still getting really bad gas mileage.
128
Santa Barbara, CA
2-strokes are peaky - I often notice that I'm holding throttle way too far open for the speed I'm going and can roll it back quite a bit and still go that same speed
however, my best mileage happens at about 25mph on level ground - I get way over 100mpg when I can do that
I also notice that, but i worry that when i bring the throttle down while maintaining the same RPM i am causing it to run lean. Also, where is the clip on your carb needle set? Mine seems to be running a little lean with the clip at the second notch from the top.
crassius
4,032
158
USA
clip position depends on which carb, what size main, and float level - find the best position for those factors on your bike
