| Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack |
03-24-2008, 12:08 AM
minor bike philosopher
attaching sprocket.
Why can't i just take the dust cover off a crusier wheel. Mount the sprocket and then cut a round piece of coke can or roof flashing and glue it to the sprocket as a new cover.
03-24-2008, 05:56 AM
Re: attaching sprocket.
All you have to do is either grind out the sprocket a little or grind the edge off the cap. I grind the edge off the cap, then stick it back on with grease.
03-24-2008, 06:35 AM
thats a plan if there ever was one. i hate the idea of grinding another sprocket.
03-24-2008, 01:08 PM
I have a problem with attacching the sprocket and the coaster brake arm, the sprocket that came with my kit is flat not dished and the coaster brake arm does not fit on its mount on the wheel with sprocket mounted on the wheel. Have others have the same problem and how do you fix it to have rear brakes. Thanks in advaance for any and all help.
03-24-2008, 01:57 PM
Yes note you have to bend the coaster brake arm. It will have to be bent to offset the front of the arm. Kind of looks like a lightening bolt. I don't have a pictures but someone probably does..... If you have a vice it is pretty easy without one you might have to use a hammer and pipe method. lay it over a pipe and hold one end then hit the other to bend it.
Much easier with a vise. You are just ending the arm out so it will clean the bolts I expect.
03-24-2008, 04:32 PM
Yeah, just mark it and put a shallow "Z" bend in it.
07-28-2009, 10:03 PM
can you tell me how to mount a sprocken to a larg back chopper wheel hub?
07-28-2009, 10:27 PM
Try manic mechanic in the right top sponsors list.Jim will fix you up.HD
You never know what you might know,you know
07-29-2009, 12:25 AM
On one Stingray I drilled new holes and bolted the sprocket to the hub.
07-29-2009, 04:41 PM
on my cruiser i took off the dust cap and tossed it,i dont need it and my sprocket fits on perfect and i didnt need to bend nothing.
| Thread Tools |
| Display Modes |
Linear Mode
