Old 01-30-2009, 09:40 PM
docgonzo docgonzo is offline
Default help please.
I have a free spirit engine I am trying to put back together,but
i need a drive wheel this one I have is toast. Where to go to find one or does someone know or have one and alternitave will be fine just a bit of help would be awesome. Thanks
Old 01-30-2009, 09:57 PM
MB-Monkey's Avatar
Default Re: help please.
a little more information about the motor would be good i tried to search for it but came up empty make a few more posts and leave a pic would be a great help.
Ride it like you stole it!
Old 01-30-2009, 10:31 PM
Dave31's Avatar
Dave31 Dave31 is offline
I believe the free spirit is from Sears????
Old 01-30-2009, 10:39 PM
Dave31's Avatar
I think the Tanaka bike bug might be the same?
you could try:
Link...... Bike Bug
Drive Wheel $28.00 The Drive Wheel is another item that has been improved on design. The rubber of the drive hub simply deteriorates with age and wear. We have put a neoprene high-speed roller skate wheel (62 mm) over the aluminum drive hub. It wears less, vibrates the engines less and bike goes slightly faster per revolution.
Old 01-30-2009, 10:42 PM
stude13 stude13 is offline
hi; you can bore out a rubber or synthetic skate board tire, usually free at a shop. get a couple and use a hole saw a bit smaller than the drive wheel, heat the tire in boiling water apply stickum to wheel and slide tire on. mitch
Old 01-30-2009, 10:59 PM
Banned
Contact EDJ on this forum...he is very knowledgeable regarding your set-up. "Members list" at the top of this page under "E".
Jim
Old 01-31-2009, 06:59 PM
Thank you all so much for the ultra fast responses and all the input. I will keep you posted and my try the skate wheel trick. I have a col bike collection so I am sure I will be posting many pics and updates. Thanks again Darrin
