Old 05-12-2015, 10:01 AM
soberguy soberguy is offline
Default Schwinn. clairmont
Anyone know the hub size to a 26 inch 7 speed Schwinn clairmont. I want to put a manicadapter on it.I hate the rag joint is not very true or a balanced setup.even my sprocket is a little larger than the spot for mounting having to eye up center and tighten.
Old 05-12-2015, 10:09 AM
crassius crassius is offline
Default Re: Schwinn. clairmont
I used to build those. The seat was a bit too tall for many of my customers, bit otherwise it was a good build. Had no problems with the rag joint on them.
When centering the sprocket, put all 9 bolts in loosely then tighten every third bolt until just snug, then use an old drill bit or other piece of steel to put between two teeth to knock high spot down with a light hammer until it is centered nicely, then continue with tightening all the bolts to get wobble out while periodically checking that center is still correct.
Sometimes I sets and thinks, sometimes I jes sets.
Old 05-12-2015, 11:34 AM
desertsteve desertsteve is offline
All the multi-speed freewheel hubs I've seen (3) measured 1.001 or so.
