Old 01-04-2015, 08:48 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: 50cc GY6 on a Bicycle??
Originally Posted by Dan View Post
Thats purdy cool. Wish we lived closer map. This sounds like it is gonna be a fun project.
Swapping ratios is great. I wanna try it with 26" wheels and your right with a smaller wheel would work better but kinda restricting in choices. Well, for my bike harum any way.
but really exciting endeavor.
Yeah I'm all alone around here when it comes to most of my hobbies.
Im just excited to see what you come up with on the whole deal, only thing I might be in trouble with would be the electrical, I wouldn't know for sure how to get he cdi all wired up, Im a mechanical fella but electrical is m weakness, very little knowledge about it.
Old 01-05-2015, 07:10 AM
Dan's Avatar
Dan Dan is offline
Staff
Maniac, only find monster big CVTs or whole quads looking for variators. Any other keywords I should search with or do ya have any links handy?
Mapster, I hear you on all things electric. Seriously, take an online course with me. Will find us a free one. Kinda fun taking these things. (I collect meaningless certificates) and way more fun and motivating when ya do it with other folks.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 01-05-2015, 07:43 AM
Davezilla's Avatar
For CVT parts. Treatland.tv has a Lot of parts and upgrades like all the different weights to set the upshift rate etc, and they also have a decent selection of the driven variator springs to fully customize for most mopeds, and with the GY6 being as popular as it is, finding cvt upgrades should be really easy from treatland, ebay, and other scooter parts places online.
If someone needs a monster CVT like for a 40hp engine (or larger), look up "snowmobile clutch" on ebay or google and you'll find all the parts you could use.
I got this little engine from treatland last summer and it has a built in CVT with plenty of upgrades available, they even make new belts for it again so no problem if the belt wears out... https://www.treatland.tv/franco-mori...ete-engine.htm ...Got this one before deciding what to put it in and I'm still undecided, it's about twice as wide as the China Doll engines so I'd need some really wide pedal cranks for a bicycle, but something like the Stingray or one of those 26" chopper type frames might work.
As far as GY6 upgrades tho, there's plenty out there for both the engine and CVT.
Old 01-05-2015, 01:16 PM
Dan's Avatar
Dan Dan is offline
Staff
Mapster, I posted a link and invite in the free ejimacation thread for a free course;
http://motorbicycling.com/showthread.php?t=56955&page=2
Old 01-05-2015, 02:29 PM
mapbike's Avatar
Got it... looks like a good course for people like myself that are electronics challenged..LOL!
Old 01-05-2015, 05:07 PM
cannonball2's Avatar
cannonball2 cannonball2 is offline
Hooking up the CDI is not a big deal it pretty simple. There are two versions an AC and a DC The DC is fed by the battery while the AC is fed by the alternator. Just have to know which one the engine is supplied with.
As far as variator tuning, a DR Pulley is about the best. It has a bigger driven face allowing higher ratios as the belt can climb higher. Also adding a few mm to the drive belt size will allow the belt to travel there as the rear driven sheave stops it short with a stock belt. I guess you all realize the clutch is in the rear sheave and not on the engine. Clutch springs come on various rpm ranges, and there are several main springs for the rear sheave to tune how it responds to the variator. I like my CVT to get to the upper ratios pretty quick. The big bore engine has the power/torque to handle faster travel to high ranges. Therefore I run fairly heavy weights. A typical take off for me is WOT and hold it there until the speed I want is reached(pretty quickly too). I have carefully tuned the variator to allow the engine to get to its max torque range. The engine immediately jumps to around 6500rpm and just stays there while the variator makes the speed happen. Once the engine unloads at around 65mph then it will rev on to around 7500 which allows the variator to finally push the belt to the full extent of the drive face and topping just north of 70mph. The design of this little power unit is pure genius!
Old 01-05-2015, 05:26 PM
Dan's Avatar
Dan Dan is offline
Staff
Great information, CB. Thanx!
Old 01-06-2015, 12:05 AM
maniac57's Avatar
maniac57 maniac57 is offline
I'm not sure what Chinese quad brands have the gy6 motors. I just know there are a bunch using basically the standard street scooter driveline with the added chain drive box. They just hang the whole scooter driveline off whatever mounts the quad wants. The engine is the same but drives a chain to the rear axle rather than the usual rear wheel.
I'd guess anything in the 150cc area is a good candidate to search for, then just look. The scooter motor quads are easy to spot from the fan shroud shape. They come in 50cc to 150cc or so under dozens of names.
http://www.alibaba.com/product-detai...606608347.html
Here's the chain drive box:
http://ezatvparts.com/gear-box-150cc...le-engine.html
If more is better, then too much is just enough.
If you can't afford it, build it yourself.
Old 01-06-2015, 05:35 AM
Dan's Avatar
Dan Dan is offline
Staff
Manual, Maniac! Manual! Could you have discovered an adaptable, already (inexpensive) mass produced, manual motorized bicycle powertrain engager!?
I have a lathe and mill. ....... hmmmmmmmmm
Old 01-06-2015, 06:35 AM
Heres a link to an atv engine. It has reverse which adds considerably to the gear box width. Notice the output shaft. It appears to have the same splines as the scoot wheel. There are 18 spline(as I remember) and 19. I bought a wrong splined wheel, mine are 19. The point of this is that more than likely the sprocket from an atv might fit the common scooter wheel shaft. Would be a simple matter to saw the shaft at the right point and drill and tap for a retaining bolt. A bike doesn't need the atv engine if this is true. Its more complex, heavier, and more $$. There are plenty of manuals for free on line I have both the 50 and 150cc loaded in my computer. Not sure how to attach them. http://www.ebay.com/itm/150CC-GY6-AT...a65abf&vxp=mtr
MotorBicycling.com
