I removed the piece of inner tube on my two motor mounts on my seat tube . I also had a piece of rubber tube around the U-bolt. Took that out . BTW I read about using the inner tube on this forum...but I didn't read the posts saying " don't use it ". I have SBP shift kit so I have two mounts on the seat tube. My frame tube is 1" and the smallest mounts that come with the kit are 1 1/8" so I made some shims and changed them out tonite. It felt solid before I changed it but the bolts were loose and I check them often. So it's rock solid now.
