bottom bracket jackshaft
Imthegrt1
42
USA
That's what I'm working on at the moment. I've seen one done on a bike but never could get any info from the guy on how he did it.
BarelyAWake
7,194
21
Maine
Keeping in mind not all bottom brackets are the same - I used 499502HNR sealed bearings w/snap rings (5/8" ID x 1-3/8" OD, same as the shift kits) & after lightly honing down the threads in the BB they pressed right in. Add a 5/8" keyed shaft, "BMX" freewheel, threaded freewheel adapter, lock collars & 5/8" keyed sprockets of your choice;
pedal driven: http://youtu.be/U10xLqTekOw
engine driven: http://youtu.be/_GTS0xG8BPM
curtisfox
6,046
3,948
minesota
FFV8 love your idea. Here is another Goldy did ..............Curt
http://motorbicycling.com/showthread.php?t=28747
http://motorbicycling.com/showthread.php?t=28747&page=14
The band might not be necessary if your clutch drum sticks out past the hub far enough (about 1/8")
There was a hole already in my clutch hub that I simply tapped 1/4 UNF to fit the pawl screw...upon final installation, I peened the end of the screw over to prevent it from unscrewing and falling out. The roll pin prevents the heavy side of the pawl from contacting the drum when running and also provides a point to fasten the return spring. I use a rare earth magnet to hold the pawl in the disengaged position when pedaling , or pushing it around. Also the heavy end of the pawl rests on the central part of the clutch hub when in the engaged position, I figured this would give it some extra strength and take some of the strain off the drum.
Imthegrt1
42
USA
So were did you get the shaft and bearing from looks real good.
