Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Tavern > Motorized Bicycle Swap And Shop Sales
Motorized Bicycle Swap And Shop Sales Buy, sell and trade your engines, parts and accessories
Old 10-30-2014, 10:54 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Exclamation FOR SALE in OC: Arrow 4.5 HP Street Racer Motor & Other Parts.
Pick up in North Orange County only from my shop.
That would be SoCal.
All motors and parts are in new unused condition.
ALL the bit's, pieces and parts for PK 80 style motors are for sale at
great prices plus some accessories.
Complete 69cc Top of the Line Motor Kits $169.99
$17.99 Speed Carb with air filter.
$14.99 Standard chrome kit exhaust.
$29.99 Speed demon exhaust in black.
$36.99 RT Carb, air filter + longer cable + correct 66 jet.
$9.99 Large front offset motor mounts with muffler clamp.
$29.99 OCC offset chopper mount with U bolts.
$11.99 41 tooth dished sprocket.
$11.99 415 kit chain. Ex quality.
$1.99 415 Master link
$9.99 4 bolt chain tensioners.
$13.99 Chinese spring loaded tensioner.
$4.99 Set of 2 rings.
$8.99 PK 80 piston. low wrist pin hole.
$4.99 Needle bearing for wrist pin. Ex quality.
$21.99 PK 80 cylinder.
$9.99 CDI with soft rubber boot.
$11.99 Magneto with upgraded ground.
$4.99 Throttle cable.
$4.99 Clutch cable with springs + cable stop.
$7.99 Clutch lever.
$1.99 each. Head gaskets or Exhaust gaskets or Base gaskets or Cover gaskets. EX quality.
$3.99 Gas Cap.
$3.99 Gas tank fuel valve.
$17.99 Straight shooter thin wall 19 mm OD intakes with hi quality USA gasket. [Uses Speed or RT Carb]
$7.99 1/4" thick laser cut steel exhaust flanges ready to weld on your custom pipe.
$24.99 Angled thin wall intakes for Honda GXH 50cc & HS 4 Strokes with gasket & studs. [Uses Speed or RT Carb]
Just a few prices and of course I sell pretty much All the other motor & kit parts.
You need it now, I got it!
Please call 714 - 3 4 1 - 7 9 9 8 from 9am to 9pm if you are a local buyer and can pick up.
Thanks.
Old 11-09-2014, 02:13 AM
Thumbs up Re: FOR SALE in OC: Arrow 4.5 HP Street Racer Motor & Other Parts.
Just got in a bunch of the thinnest head gaskets to bump your compression
and set your head squish band to a smaller size for more power.
Thin Aluminum head gaskets for the 66cc to 69cc 47mm bore Chinese motors with 8mm studs
0.017" thick for Only $3.99
These gaskets are thinner than the stock one that is about 0.025" which
is like milling 8 thousands off the top of your cylinder.
All my 69 cc 40 mm stroke motors are being built with these thin higher compression gaskets.
Still selling the stock 25 thousand head gaskets for only $1.99
Old 11-19-2014, 04:34 AM
joegrind joegrind is offline
Default Re: FOR SALE in OC: Arrow 4.5 HP Street Racer Motor & Other Parts.
Can you send me your address joedgrind@gmail.com I need parts
Old 11-19-2014, 11:49 AM
Arrowcycles Arrowcycles is offline
$375
Arrow 4.5 HP Street Racer motor.
Includes RT Carb with a 66 jet + air filter.
NGK B8HS plug in CR Machine 5.8cc Competition head.
Arrow reed + reed ported cylinder.
Upgraded magneto.
Will include extra head and exhaust gaskets.
Does not include a Torquer II exhaust.
$75 [sells for $100] Your choice of black anodized or silver.
Pirate Cycles spring loaded chain tensioner with ball bearing idler sprocket.
$50 [sells for $75]
Pirate Cycles spring loaded chain tensioner without ball bearing idler wheel.
$79 HD Lightning CDI
$7.99 Clutch lever.
$3.99 Gas Cap.
Thanks.
So if you're selling my motors, where are you getting them from Neil? Not me. is that new or a used motor ?
Old 11-20-2014, 08:54 PM
Huffydavidson's Avatar
Huffydavidson Huffydavidson is offline
STREETRACER/MANUFACTURER
And the HD'LIGHTNING kit is the WORLD'S BEST CDI KIT MONEY CAN BUY GUYS!!!1
"RIDE IT LIKE YOU STOLE IT"
Old 11-20-2014, 09:38 PM
SOLD!
Hi Dave,
yes, I am selling one of your motors that is in brand new unused condition.
Never been installed on a bike or started.
I bought the Arrow Street Racer motor off one of our local mutual customers.
The original magneto was removed. It will be replaced with one of my new,
upgraded mags.
I originally bought it to get one of my customers who races into the China
girl Beginner class up to the next class but he backed out of taking it.
Note that the $375 price does not include a Torquer II pipe but does come
with a Runtong flat slide carb with the right jet.
Will throw in a few head, base and exhaust gaskets too so it's a good deal
for a great performance motor.
PS: All the motors and parts I am listing for sale here are new, unused and I
stand behind them with a warranty.
thanks
Old 11-23-2014, 03:03 AM
hsvmick's Avatar
hsvmick hsvmick is offline
g'day Neil,
can i ask about the upgraded mags of your's ?are they pushing more ohm's out
cheers Mick
Old 11-28-2014, 05:39 PM
KeithSeymour KeithSeymour is offline
Good guy who knows his stuff. He made himself available to talk on the phone about the differences between quality motors and cheap ones.
Old 06-06-2015, 12:22 PM
CarpsCustoms CarpsCustoms is offline
hey MBR do you balance these motors yourself?? Whats the typical cruising speed for a stock one & idk, lets say a 40t sprocket... They dont start getting very shaky till around 30mph or so correct??
Life is like riding a bicycle. To keep your balance you must keep moving. -Einstein
Old 07-08-2016, 11:59 AM
donnell donnell is offline
I am looking for cam shaft top gear the one with the lobe on it and push rods for a ghost racer 7g 49cc hua sheng engine can you help me out my email is donnellf@comcast.net or can i call you hear is my number 217-257-4421
thanks
Donnell
MotorBicycling.com
