Old 01-11-2009, 05:01 PM
Spunout's Avatar
Spunout Spunout is offline
MB Builder Extraordinaire
Default HEET/GasDry, winter riding and frozen jets
the first time my bike quit running during a snowstorm, i'd assumed snow/slush got sucked up into the carb.
today, there wasnt snowfall from the sky and it quit.
my father-in-law is a airplane mechanic, and this is what he told me:
the gas in the carb is already cold. during extreme cold, it can evaporate (making carb even colder) and the remaining moisture will amass in the venturi. so...plugged jets.
with the bike still outdoors, we took a heat gun to the carb and after a few minutes it started right up.
he said HEET or other gasoline dryers (methyl alcohol) should do the trick.
Originally Posted by Dan View Post
sn0rk.
Originally Posted by Bikeguy Joe View Post
You are one sick man spun, I like that quality in a person.
Old 01-11-2009, 05:04 PM
Bikeguy Joe's Avatar
Default Re: HEET/GasDry, winter riding and frozen jets
Fo'sho', just don't use too much.
This is one time that "too much is never enough" doesn't apply.
Old 01-11-2009, 05:07 PM
You can get "carb icing" in any engine, not just aircraft. I have had it happen on a motorcycle (Honda 700SC) I was riding it to work when it was around 38 degrees, and it just crapped out. It was warm enough that after the bike sat for a few minutes, it fired back up.
When you ride and it's high humidity, even if it's in the 50's it can and does happen.
Old 01-11-2009, 05:11 PM
Finfan's Avatar
Finfan Finfan is offline
Could the oil in the fuel mixture get viscous enough to gum up the carb when it's that cold?
-and-
I'm not lost, I'm exploring!
Old 01-11-2009, 05:35 PM
NEAT TIMES's Avatar
NEAT TIMES NEAT TIMES is offline
Yrs Ago Snowmobiling In Northern Wis. Ran A Lot Of Heet Thru My Engines. Was Always Told It Would Ruin Carb Diaphram And Gaskets Etc. For Yrs I Never Had Any Problems. But I Sure Had A Bellyfull Of Working On Other Riders Machines, Out On The D*m Cold Trails. Those Engines Are Covered By The Hood So May Be Warmer. I Think It Was Mainly Water Or Snow In The Gas, 2 Cycle. One Time A Friend Was Mixing 5 Gals Gas With Oil. He Poured A Quart Of Oil Into The Empty Can, Then Filled It With Gas. I Told Him He Should Have Like A Gal Of Gas In The Can Then Add Oil And Shake It Good, Then Fill Can. He SaiD That Wasn`t Needed. Later When He Poured The Gas Into The Snowmobile, The Oil Came Out Last!!! He Did It THE RITE Way After That.
PUMP YOUR BRAKES HAVE TO LOVE WINDOWS & THE INTERNET
NEVER BEAT ON IT, GET A BIGGER HAMMER
"A MAN WHO SAY`S IT CANNOT BE DONE SHOULD NOT INTERRUPT A MAN DOING IT"
Old 01-11-2009, 05:56 PM
Not likely.
Old 01-11-2009, 07:20 PM
Spunout's Avatar
i have a 3/4gal tank, so i figger just a couple capfulls
sn0rk.
Old 01-12-2009, 01:30 PM
offroad offroad is offline
so would it help to run the engine hotter by putting some strategic covers on the engine to make it hotter in cold times of the year?
Old 01-12-2009, 03:11 PM
NEAT TIMES's Avatar
It Might, Although It Is Sucking The Air In From The Rear, Some Snowmobiles Did Also. Have You Tried It With The HEET Added. Maybe NOT Enough With The Heet??
Old 01-12-2009, 05:11 PM
2door's Avatar
2door 2door is offline
Okay, I'm going to get arguments here but I'm only passing along what I was told by the mechanic who comes to service the emergency generators where I work.
I noticed he had several cases of windshield washer fluid in the bed of his service truck, five cases, four gallons to a case, and asked him why he carried so much. He told me they put it in the fuel tanks to evaporate the moisture from the deisel fuel. He said it is the same as HEET, and cost a lot less. I asked "what about gasoline engines?" He said same same. The alcohol in the washer fluid evaporates and takes the water with it.
Okay, I'm ready for responses on this one. and it's not my opinion. The guy works for Onan, a big manufacturer of generators and other engine powered equipment.
