Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 01-10-2009, 07:45 AM
TigerToothBikes.com's Avatar
TigerToothBikes.com TigerToothBikes.com is offline
UK Dealer
Default Switch Cluster. Light, Indicator, Horn etc
Have found this part listed on eBay, any ideas if it could work? Would want it running of a battery but its 24v. Really like the idea....
24v Electric Scooter Switch Cluster Light Indicator Hor on eBay, also Parts Accessories, Electric Scooters, Scooters, Sporting Goods (end time 02-Feb-09 22:09:10 GMT)
For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at
www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
Old 01-10-2009, 09:44 AM
TexasDav's Avatar
TexasDav TexasDav is offline
Default Re: Switch Cluster. Light, Indicator, Horn etc
Sence it has no speed control you could use it with and voltage you want, It is just switchs I would go for it if you like the set-up. Might even thread the wires thru the handle bars and make it real clean.
Always do a pre-ride check. Make it a habit, and ride safe.
Old 01-10-2009, 10:01 AM
UK Dealer
Tah for that, really cautious as i know diddly squat about electronics!
Visit us at
Old 01-11-2009, 12:55 AM
MB-Monkey's Avatar
its just switches is exactly right you can use any voltage lights you want these are grounding switches so you would run a primary positive voltage in parallel just meaning a shared positive from the battery source then connect the grounds of the lights to the switch cluster and the switch cluster should have a master ground. you can do it the opposite if you want but i would rather float the ground then run the power thru the switch.
There is my two cents
Old 01-11-2009, 04:51 AM
UK Dealer
Thanks Huffy, i'm now buying in a horn and rigging up lights and indicators
Visit us at
