Old 04-02-2008, 08:07 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: New here.
Now my clutch makes that sound when I let it out to fast. I wonder if yours is slipping or something like that.
Old 04-02-2008, 08:55 PM
Ilikeabikea's Avatar
Did you put the little dab of grease on the gears? Norms engine teardown shows where to put it and how much to use..............
Nothing sucks more than being in the middle of an argument and you realize you are wrong.........
Old 04-02-2008, 10:15 PM
James Sparks's Avatar
James Sparks James Sparks is offline
I read that post and post checked the engine when I first got it. It didn't have any metal dust anywhere and the gears had some grease on them. It's a wierd sound. Like an alternator belt squeal. It doesn't run different or vibrate any more, it just squeals. I'll check the grease again.
Old 04-03-2008, 06:45 AM
I've heard a lot of people say they heard a squeal, I think the deduced it was from the intake or it may have been various open ended tubes/ect whistling.
Old 04-10-2008, 07:19 PM
The squeal sound is pretty much gone. Not sure what it was, just went away. I have had the worst luck with my rear tire. I've had three flats in the last 5 days. Nails every time. On my way to the same store every time. Guess I'm gonna have to find somewhere else to buy cheap wine. I think the engine is getting pretty close to broke in. When I first put the kit on, it started easy, but had to run for a few minutes before the throttle would work. Now it's hard to start, I have to roll down the big hill I live on(thankfully I live on the top of the hill) for about 45 seconds before the engine will fire up, but as soon as it starts it runs pretty smooth. I'm about half way through my third tank, and the idle adjustment screw still isn't doing anything. It is really annoying, every time I justwant to stop for a second I have to kill the engine and pedal to restart it because as soon as I pull in the clutch lever the engine revs up to about, well I really have no idea what the rpms get up to, but it is so high I have to shut it off. It is loud and annoying when I hold in the clutch. Hopefully by the time this tank is gone I can adjust the idle. I love ridin this thing though, two of my friends have said they are going to order kits, we'll see if they do. It would be nice to have someone to ride with.
Old 04-10-2008, 08:26 PM
deacon's Avatar
that doesn't sound right. When you turn the throttle off the needle should almost close the jet even with the idle wrong it shouldn't make that much difference.
I can think of only one possibility
the bolt at the top of the carb on what looks like a buddist temple needs to be adjusted to give more slack to the cable. that also adjusts the carb in a way.
I would try adjusting the nut on top of the carb where the cable runs through though. Start the engine and wind the nut in or out I cant remember which way it goes now. You will be able to tell the difference.
Old 04-10-2008, 08:33 PM
Thanks Deacon. I thought it was just part of the break in. When me and my buddy first put the kit on I thought we put all the slack in it we could. I'll give it a look real quick. I will love ridin that thing way more if I can just hold the clutch in instead of always killin and restartin the thing.
Old 04-10-2008, 08:49 PM
I checked the throttle cable and there wasn't any more slack I could put in it. I adjusted it the other way a little just see if it would make a difference. I'm gonna go on a little trip and see what happens. I'll be back in about a half hour.
Old 04-10-2008, 08:52 PM
deacon's Avatar
You should be putting the slack inside the carb not outside. The other way is probably the right way.
Old 04-10-2008, 09:31 PM
I'm gonna have to agree with you on that one Deacon. That did not help. Made it way worse. Problem is, I already have all the slack I can get in it. I'm gonna take the throttle grip apart and see if something is bound or something in the grip.
MotorBicycling.com
