Old 01-09-2009, 08:19 PM
Qdot Qdot is offline
Default the thing wont idle.
So ive got the chinese 80cc motor. Heres the skinny. It ran great for about a month and then it started not wanting to idle and then it wouldnt start at all. So i bought a better spark plug and cleaned the carb out. It starts up right away but will not idle at all and is even backfiring into the carb a bit and the carb keeps over flowing with gas. Could i have a vacuum leak or could my timing be out to lunch?
Old 01-09-2009, 08:31 PM
toytime toytime is offline
Default Re: the thing wont idle.
Have you got a fuel filter?
Did you screw around with the float level in the carb?
Has it backfired bad enough to break your "key" on the magneto/flywheel?
Is the sparkplug wire wet?
Is your kill switch wet and shorting out a bit?
I don't know. You are going to get to know your bike very well, I think.
Have fun!
Old 01-09-2009, 08:36 PM
i have no fuel filter.
I didnt know you could screw around with the float level.
I dont think it has backfired that bad. Just little pops.
Im not running a kill switch.
I think its just a carb problem but i dont know what problem that is.
Old 01-09-2009, 09:00 PM
I think you got dirt in the carb and that is why it got worse and worse untill it would not run well or idle.
You carb is much like the float in your toilet tank. Have you ever adjusted your water level by bending the metal rod in your toilet tank?
When the carb is apart, the float should be level, I only mention this because I have the feelling you may have buggered it up when you had it apart.
Either way, I think you have to take it apart and have a look. Get a $4.00 inline fuel filter, it's one of the most important parts in your fuel system.
Old 01-09-2009, 09:26 PM
i let the carb sit apart in my parts washer over night and then i cleaned out the jet with a sewing needle and then i blew it out with an air compressor so i think its pretty clean but i dont see what i could have buggered up on it?
Old 01-09-2009, 09:55 PM
You said gas was dripping out of your carb.
The float, inside the carb is not doing it's job. I don't think I'm wrong to say that the extra gas ,from a stuck or mis-adjusted float , is being sucked into your cylinder when it's running.
It's a problem that can be solved without spending any money and you really have nothing to lose, and don't forget to get a filter.
Old 01-09-2009, 09:57 PM
How do you adjust the float? i didnt know you could/had to do that.
Old 01-09-2009, 11:05 PM
2door's Avatar
2door 2door is offline
Try looking here for float level adjustments and other carb related issues.
http://motorbicycling.com/f4/carbure...build-195.html
Old 01-09-2009, 11:11 PM
OH i think i know what the problem is. I think the floats needle seat is full of crap. That would explain why it was running like crap for no reason.
Old 01-10-2009, 12:09 AM
hiker472's Avatar
hiker472 hiker472 is offline
That's what happened to me, and also had my float fill up with gas...........check that your float is good too.
Don't feed the bears....
